Errors when booting
Whenever I boot my system, I get a bunch of errors, but the system seems to boot fine (into kde plasma)
Error set 1:
5.6696871 ACPI Error: Field LAFUO) Base Offset Width 512+0-1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163) 5.670972) ACPI Error: Aborting method AFUB. STA due to previous error (AE_AML_REGION_LIMIT) (20230628/psparse-529) Starting File Systen Check on /dev/disk/by-uuid/CD79-1836...
5.6827631 ACPI Error: Field [AFUO] Base+Offset+Width 512+0+1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163) 5.683440) ACPI Error: Aborting method AFUB. STA due to previous error (AE_AML_REGION LIMIT) (20230628/psparse-529) 5.6871861 ACPI Error: Field [AFUO] Base+Offset+Width 512+0+1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163) 5.688085) ACPI Error: Aborting method AFUB. STA due to previous error (AE AML REGION LIMIT) (20230628/psparse-529) 5.707464) ACPI Error: Field (AFUO] Base Offset Width 512+0+1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163) 5.708586) ACPI Error: Aborting method AFUB.STA due to previous error (AE_AML REGION LIMIT) (20230628/psparse-529) I 5.7158291 ACPI Error: Field [AFUO] Base Offset Width 512+0+1 is beyond end of region [COMP] (length 512) (20230628/exfidio-163) I 5.716218] ACPI Error: Aborting method AFUB.STA due to previous error (AE AML REGION LIMIT) (20230628/psparse-529)
Error set 2:
28/psobject-220)
[ 0.147644) ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.X HCI.RHUB.HS14. PLD), AE_ALREADY_EXISTS (20230628/dsuload2-326)
0.1476471 ACPI Error: AE ALREADY EXISTS, During name lookup/catalog (202306 28/psobject-220)
0.342280) ACPI Error: Field LAFUO] Base Offset Width 512+0+1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163)
0.3422891 ACPI Error: Aborting method NAFUB. STA due to previous error (AE
t
0.3629321 ACPI Error: Field LAFUO] Base Offset Width 512 0-1 is beyond end of region [COMP] (length 512) (20230628/exfldio-163)
0.3629371 ACPI Error: Aborting method NAFUB.STA due to previous error (AE AML REGION LIMIT) (20230628/psparse-529)
0.392369) ACPI Error: Field [AFUO] Base Offset Width 512 0-1 is beyond end of region [COMP] (length 512) (20230628/exf1dio-163)
0.3923741 ACPI Error: Aborting method NAFUB. STA due to previous error (AE
AMIL REGION LIMIT) (20230628/psparse-529)
t
0.392378) ACPI Error: Hethod execution failed NAFUB. STA due to previous er For CAE AML REGION LIMIT) (20230628/uteval-68)
t
0.523290) integrity: Problem loading X.509 certificate -65
0.523303) integrity: Problem loading X.509 certificate -65
I have no idea what this means as I am quite new to Linux and just want to know what is causing this.
Edit: one of my friends who is much smarter than I am, told me it was a ram issue and had to do with something software.
It’s not uncommon to get acpi errors or warnings. Just a long everything is working, you likely have no problems.
What is an acpi error though, it doesn’t bother me that I’m getting errors, it just annoys me that I don’t know what the error is.
Have you checked if there is a Bios update for your board?
As posted by @ricklinux check for Bios update and install to keep it updated.
Some info on acpi:
A uefi update didn’t fix the issue, but switching back to grub from systemdboot did fix the issues.
