Errors occurred, no packages were upgraded
Directly after a fresh install, I log in and it starts the initial set of system updates, which promptly fail:
(87/87) checking keys in keyring [----------------------] 100%
(87/87) checking package integrity [----------------------] 100%
(87/87) loading package files [----------------------] 100%
(87/87) checking for file conflicts [----------------------] 100%
error: failed to commit transaction (conflicting files)
endeavouros-theming: /usr/share/endeavouros/EndeavourOS-icon.png exists in filesystem
endeavouros-theming: /usr/share/endeavouros/EndeavourOS-logo.png exists in filesystem
endeavouros-theming: /usr/share/endeavouros/splash.png exists in filesystem
upstream update failed.
Press ENTER to close this window:
This is a disappointment. Earlier this year, I discovered Antergos was my favorite distro, and a month later the project shut down. Endeavour seems like the spiritual successor, I would love to be able to use this as a replacement.
Known issue. See this thread: Eos-update-notifier update requires manual intervention
Hope it helps.
Works perfectly. Thanks. The antergos forum was always helpful, I see that hasn’t changed either :slight_smile:
I was not on Antergos forum. I’m just on this one, being one of the beta tester :smiley:
By the way, I think you can check “solved” case :slight_smile:
Welcome to EndeavourOS @darkoverlordofdata, don’t be disappointed too fast.
Don’t forget to use the Welcome app. you could reach lot of links for help and see also the Wiki, lot of good tips there to start then ask here in the forum when you need.
Have a long journey with Eos. :rocket:
Have a long & pleasant endeavour, I should say. :wink:
