Today, when I chose “Update System” through the Welcome GUI, I saw this: warning: insufficient columns available for table display Does this mean that I should widen the terminal window?
Further on in the update process, I got some instances of error: failed retrieving file ...
and also this: warning: too many errors ... skipping for the remainder of this transaction
Despite all this, looking at /var/log/pacman.log indicates that all packages installed successfully. How was the update successful? Did pacman silently/seamlessly use one of the other mirrors?
For reference this is my current etc/pacman.d/mirrorlist:
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --verbose -c IN --protocol https --protocol http --sort rate --latest 18
# When: 2021-11-02 10:23:09 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2021-11-02 10:22:16 UTC
# Last Check: 2021-11-02 10:16:41 UTC
## India
Server = http://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
## India
Server = http://mirror.cse.iitk.ac.in/archlinux/$repo/os/$arch
## India
Server = https://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
## Worldwide
Server = http://mirror.rackspace.com/archlinux/$repo/os/$arch
Server = https://mirror.rackspace.com/archlinux/$repo/os/$arch
But
Your mirrors are too slow and some seem to not be available (error 503). Run reflector simple again and select the below countries. Increase mirrors from 10 to 20 if you want. Will give you much better mirrors and those errors will go away.
Thanks to everyone! I was in time to get updates to KDE Gears.
I updated the mirrors using s4ndm4n’s suggestions & maximized the terminal. The process completed without any errors or warnings.
However, the mirror-rating.log looked like this:
[2021-11-04 20:19:20] INFO: rating 10 mirror(s) by download speed
[2021-11-04 20:19:20] INFO: Server Rate Time
[2021-11-04 20:19:27] WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:19:27] INFO: https://archlinux.thaller.ws/ 0.00 KiB/s 0.00 s
[2021-11-04 20:19:33] WARNING: failed to rate http(s) download (https://america.mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:19:33] INFO: https://america.mirror.pkgbuild.com/ 0.00 KiB/s 0.00 s
[2021-11-04 20:19:38] WARNING: failed to rate http(s) download (https://mirror.f4st.host/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:19:38] INFO: https://mirror.f4st.host/archlinux/ 0.00 KiB/s 0.00 s
[2021-11-04 20:19:44] INFO: https://mirror.chaoticum.net/arch/ 1200.58 KiB/s 4.95 s
[2021-11-04 20:19:52] WARNING: failed to rate http(s) download (https://phinau.de/arch/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:19:52] INFO: https://phinau.de/arch/ 0.00 KiB/s 0.00 s
[2021-11-04 20:19:58] WARNING: failed to rate http(s) download (https://ftp.halifax.rwth-aachen.de/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:19:58] INFO: https://ftp.halifax.rwth-aachen.de/archlinux/ 0.00 KiB/s 0.00 s
[2021-11-04 20:20:04] WARNING: failed to rate http(s) download (https://arch.mirror.constant.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:20:04] INFO: https://arch.mirror.constant.com/ 0.00 KiB/s 0.00 s
[2021-11-04 20:20:10] WARNING: failed to rate http(s) download (https://mirror.pseudoform.org/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:20:10] INFO: https://mirror.pseudoform.org/ 0.00 KiB/s 0.00 s
[2021-11-04 20:20:15] WARNING: failed to rate http(s) download (https://mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:20:15] INFO: https://mirror.pkgbuild.com/ 0.00 KiB/s 0.00 s
[2021-11-04 20:20:21] WARNING: failed to rate http(s) download (https://de.arch.mirror.kescher.at/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-04 20:20:21] INFO: https://de.arch.mirror.kescher.at/ 0.00 KiB/s 0.00 s
And this is the current mirrorlist:
# With: reflector --verbose -c AU -c DE -c IN -c IL -c NO -c SG -c US --protocol https --sort rate --latest 10 --age 12
# When: 2021-11-04 14:50:21 UTC
# Retrieved: 2021-11-04 14:48:11 UTC
# Last Check: 2021-11-04 14:40:15 UTC
## Germany
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
## Germany
Server = https://archlinux.thaller.ws/$repo/os/$arch
## United States
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
## Germany
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
## Germany
Server = https://phinau.de/arch/$repo/os/$arch
## Germany
Server = https://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
## United States
Server = https://arch.mirror.constant.com/$repo/os/$arch
## Germany
Server = https://mirror.pseudoform.org/$repo/os/$arch
## Germany
Server = https://mirror.pkgbuild.com/$repo/os/$arch
## Germany
Server = https://de.arch.mirror.kescher.at/$repo/os/$arch
## Worldwide
Don’t worry much about the rating log. It happens when the reflector can’t ping the mirror server. As always DE (Germany) mirrors seem to be the top dog for IN and SL. If possible run reflector once or twice a week to keep the best active mirror in the list.
Also, if a reply solved your issue please mark the reply as the solution. So, the thread would get closed in 2 days and the solution would be easier to find for other users with similar issues.
i see this on several users from india or Bangladesh and that area… in some parts they never get nearby mirrors working and reflector give them only US DE in the list
