Error starting domain: internal error: process exited while connecting to monitor: 2023-04-22T15:07:33.733713Z qemu-system-x86_64: -blockdev {"driver":"file","filename":"/home/parasetu/Downloads/Win10_20H2_v2_English_x64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}: Could not open '/home/parasetu/Downloads/Win10_20H2_v2_English_x64.iso': Permission denied
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 72, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 108, in tmpcb
callback(*args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 57, in newfn
ret = fn(self, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/domain.py", line 1402, in startup
self._backend.create()
File "/usr/lib/python3.10/site-packages/libvirt.py", line 1373, in create
raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: internal error: process exited while connecting to monitor: 2023-04-22T15:07:33.733713Z qemu-system-x86_64: -blockdev {"driver":"file","filename":"/home/parasetu/Downloads/Win10_20H2_v2_English_x64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}: Could not open '/home/parasetu/Downloads/Win10_20H2_v2_English_x64.iso': Permission denied
…points to missing rights. Are you root? If not, try running the program from a root-shell, or via sudo. If that’s not an option, you can chown the file like this:
sudo chown parasetu /home/parasetu/Downloads/Win10_20H2_v2_English_x64.iso
I did run your command but it didn’t work ![]()
Run this: find $HOME ! -user $USER in a terminal.
It shouldn’t output anything. If it does, you have some ownership issue in your home directory.
Is the file actually there, in that folder?
It did display
now please help me to also resolve this, thanks ![]()
find: ‘/home/parasetu/doxygen-clang/pkg’: Permission denied
/home/parasetu/Downloads/virtio-win-0.1.208.iso
find: ‘/home/parasetu/websocketpp-git/pkg’: Permission denied
find: ‘/home/parasetu/cmocka-git/pkg’: Permission denied
This shows, @pebcak was right… your user isn’t owner of everything in your $HOME folder.
There are files that have shared rights with $ROOT within $HOME, therefore it is not a one-size-fits-all solution to chown all files within the user’s home-folder, afaict. Although in your situation, it might just suffice, to do:
sudo chown -R parasetu /home/parasetu/*
But I’m pretty sure that some folks here know a way around that?!
Idk how an -R worked here , what did you remove , but it has worked for me
thanks for helping me out ![]()
chown --help
man chown
