Error in Forum Post
On this forum post: Mercury Neo with Linux 6.13.7 and Arch mirror ranking bug fix , it states, " When choosing Systemd in the auto-install option, the installation process will now create a 2GB EFI partition instead of a 1GB partition."
I find that when I choose the grub boot option, it also creates a 2GiB EFI partition. I’m not sure if that is an error on the forum posts part or an error in the installation process. I would like clarification on that please and hopefully get it fixed soon.
Welcome to the community @iSuck :wave::partying_face: :enos_flag:
It looks like the increase to 2GB might apply to both systemd-boot and grub. If I’m not mistaken, @dalto committed that change, so he might be able to confirm.
When it creates an EFI partition, it will always be 2 GiB no matter which bootloader is selected. This was the behavior before the change as well. It was just 1 GiB instead of 2 GiB.
It looks right to me, the installer will create a 2G partition, whereas it used to create a 1G partition. The 1G information may not be necessary at all. I guess it’s for old timers who are used to the old way.
