is a typo i bet? sudo systemctl enable avahi-daemon should be god to go
but if you connect the printer via USB you do not need any network services for the printer…
Not clear too if you can print and only scanning is not working?
And where the printers recognized to be able to do the nozzle clean action?
does the imagescan utility starts and show the scanner? or do you use xsane tool and it does not find it? there is also simple-scanyay -S simple-scan what is a very simple tool to scan…
Error Yes.Hacker modified text when copy &paste carried out.
I am connecting using USB. No network being used.
Epson printer utility package installed afer QT4 package opens up and performs its duties.
imagescan v3 front end is not coming up.Not showing up in programs installed as well.
So i can not do either print or scan.Image scan utility is kind of a dead.
xsane starts but does not scan.fails.
What should be the code to be pasted in removable media for printers?Appreciate help
And let it it find your printer – selecting the fitting driver … without this it will not print.
But if printing works… and the epson print toll detects and setup the printer it will be fine too.
