I have a little issue, EndeavourOS Wellcome does not start, and I don’t know why. Thank for help. Franklin
Get into terminal window and enter
eos-welcome --enable
Welcome also has the option to disable welcome
eos-welcome --disable
HTH
Pudge
Note that welcome can be started even if it is disabled:
eos-welcome --once
Option --once
temporarily allows welcome to run, and leaves it disabled after that.
Thank you so much for your support.
Thank you all very much, I managed to solve the small problem, good day
Great to read your issue has been resolved.
Please mark the post that contains the solution, so that others may find this solution as well.
