Eos-sendlog certificate issue
The pastebin service clbin.com used by eos-sendlog by default seems to have a certificate issue.
A workaround is to edit file
/etc/eos-sendlog.conf
and set another supported value for variable EOS_SENDLOG_URI, e.g.:
EOS_SENDLOG_URI=wgetpaste
and install wgetpaste to use it if you chose it …
:nerd_face:
sudo pacman -S wgetpaste
you can just replace it also with this :slight_smile:
Preferably install wgetpaste-eos. :wink:
But wgetpaste should work too.
Looks like their certificate has expired.
$ curl -I https://clbin.com
curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
I’d assume they will fix that fairly quickly.
note that the link will expire after one day.
dpaste_screen
https://dpaste.com/A4UMYKPY9
wgetpaste-eos
we have everything … just back from the holidays… still need to load some backups into brain i think :wink:
yea lets hope clbin will renew the certificate … there is also http://ix.io but no https :wink:
http://ix.io/4850
Pastebin services are not equal…
Let’s hope clbin.com fixes the certificates soon.
https://clbin.com/ is working again. the certificate problem has been fixed.
Ottimo e funzionale
