Would it be possible to add the linux-lqx
pattern to the eos-reboot-required.hook from eos-bash-shared?
Welcome to the forum!
And thanks for the question. By default we support only the official packages .
But you are free to modify the contents of that file in your system (after all, your system, your rules). Then, on possible updates to this file, you need to merge your changes.
Thatâs fair. I realized afterwards that it was a separate repo and I guess I was surprised to see it was a simple pattern match on the package name and not some other metadata, i.e. âhey PKGBUILD called dract/install-kernelsâ for example.
I ended up at liquorix from the official Arch wiki when trying to find out what this âzen kernelâ people on Matrix were talking about, and Iâm still not clear on the details between zen and lqx, but it seems to work fine!
https://wiki.archlinux.org/title/kernel#Officially_supported_kernels
You could make a hook for the linux-lqx in /etc/pacman.d/hooks.
Doing so, you wouldnât need to bother that the changes you have made to eos-reboot-required.hook will be overwritten on future updates to that file.
What a lot of the hooks for kernels do is use a path trigger. Something like this:
[Trigger]
Type = Path
Operation = Install
Operation = Upgrade
Target = usr/lib/modules/*/vmlinuz
If you need the specific name of the kernel, you can use pkgbase
instead of vmlinuz
