I did not modified the /etc/fstab primary. I modified only to test if the Remount fs error still appears with the / commented out (i found this solution somewhere in arch-forum)
So i tested out a little bit:
running the original LTS kernel, no snapshot and / is not outcommented:
findmnt --real
/ /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@] btrfs rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=256,subvol=/@
├─/home /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@home] btrfs rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=257,subvol=/@home
├─/run/user/1000/doc
│ portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1001
├─/var/cache /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@cache] btrfs rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=258,subvol=/@cache
├─/var/log /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@log] btrfs rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=259,subvol=/@log
cat /etc/fstab
UUID=7ECC-2F22 /boot/efi vfat fmask=0137,dmask=0027 0 2
/dev/mapper/luks-a6b66b0d-5fb4-4a5d-a18b-f4859b35cea0 swap swap defaults 0 0
/dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f / btrfs subvol=/@,noatime,compress=zstd 0 0
/dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f /home btrfs subvol=/@home,noatime,compress=zstd 0 0
/dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f /var/cache btrfs subvol=/@cache,noatime,compress=zstd 0 0
/dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f /var/log btrfs subvol=/@log,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
vfat rw,relatime,fmask=0137,dmask=0027,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount
running a snapshot and / is not outcommented:
findmnt --real
/run/user/1000/doc
/boot/efi /dev/sda1
cat /etc/fstab
running a snapshot and / is outcommented:
findmnt --real
/home /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@home] btrfs rw,noatime,ssd,space_cache=v2,subvolid=257,subvol=/@home
/run/user/1000/doc
/var/cache /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@cache] btrfs rw,noatime,ssd,space_cache=v2,subvolid=258,subvol=/@cache
/var/log /dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f[/@log] btrfs rw,noatime,ssd,space_cache=v2,subvolid=259,subvol=/@log
/boot/efi /dev/sda1
cat /etc/fstab
#/dev/mapper/luks-63e0389e-3fe6-483f-9ac2-63aee37e5e7f / btrfs subvol=/@,noatime,compress=zstd 0 0
