Hello, I have this problem that I cannot understand why it is happening in the first place. It all started the first time i tried endeavor year and a half ago. I installed it on my work laptop as I thought it could work even better than Manjaro i have been using for years. The moment i installed Endevour I realised that its really chop and laggy in all places ( KDE Plasma ).
Moving windows arrounds was choppy, opening the taskbar items was delayed and laggy, and some software like teams from aur and browser were laggy as well ( tried both turned on and off hardware acceleration ). Then decided to switch to Manjaro and everything was perfectly fine. Now that spring has came I wanted to do some spring cleaning and to reinstall the system. I wanted to give a chance to EndeveourOS again so i installed it, but again it seems to have the same issues.
I want to use EndeveourOS over Manjaro but it aint letting me. Also when I installed displaylink and then whenever a second screen was active, the movement of windows became even more choppy. ( though i think i fixed that by installing evdi-git instead of evdi )
Have you tried installing any other Arch Linux based systems, i.e. Arcolinux, Archman, Archcraft, Garuda, or RebornOS? Just curious if other Arch spins are giving you similar results?
Manjaro is another distribution that is based on Arch but is not Arch. Manjaro holds back updates and does a lot of its own things. Not trying out something from someone who is trying to help isn’t going to encourage others to help
i never said i didnt try wayland on Endevour, I only shared my finding on manjaro, on endevour it seems it makes no noticable difference, maybe its a bit better but it could be my eyes playing
I think you misunderstand me. I am saying that Endeavour is NOT Manjaro. It is a different team with a different philosophy and a different approach to users. Manjaro does things its own way. They are two different projects with two very different approaches.
Alright then, i shall not be comparing Manjaro with EndevourOS then. Also after everything above combined, it might be running slightly better, ill need a few days to see
Is your monitor and laptop both at the same refresh rate? On x11 it defaults to whichever has the lowest refresh rate for both screens, with wayland it won’t have that problem. This could explain why it feels choppier and laggier. Also make sure you have the correct refresh rate in KDE system settings but I’m assuming that was already set.
I feel ashamed to admit that I have found what the issue was and so by accident. I realized I haven’t heard the fans on the laptop spin for a long time, and immediately checked the power settings…
Seems like even though I had the laptop plugged in it didn’t make it automatically go to performance mod how I guess KDE on Manjaro was configured and never thought of checking it. Well anyways I learned a lesson today and thanks for y’alls help.
