The OS randomly freezes, I already switched to the LTS kernel, but it seems like that was not the issue.
I don’t know what causes it. It may be the hardware, so below is the output of the lshw -short command. Is there a way to troubleshoot this issue? It’s really frustrating when it freezes in the middle of a coding session… :))
If you have already tried switching kernels, the next thing to do is test your memory.
Frequent hard freezing is usually caused by hardware or drivers.
Could you post the link for this command for your hardware?
inxi -Faz | eos-sendlog
Kernel: 5.15.60-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=7d173a4b-9955-42eb-889d-3feb1e3e1e67 rw loglevel=3 nowatchdog
nvme_load=YES
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL
serial: <superuser required> Chassis: type: 10 v: Lenovo Yoga S740-14IIL
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: BYCN39WW date: 05/28/2021
Battery:
ID-1: BAT0 charge: 53.6 Wh (94.2%) condition: 56.9/62.3 Wh (91.3%)
volts: 17.4 min: 15.4 model: SMP L19M4PD2 type: Li-poly serial: <filter>
status: charging cycles: 970
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 built: 2019-21 process: Intel 10nm family: 6
model-id: 0x7E (126) stepping: 5 microcode: 0xB2
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1099 high: 1101 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1095 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1101 bogomips: 23961
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: N/A
alternate: nouveau non-free: 515.xx+ status: current (as of 2022-07)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 3
speed: 8 GT/s lanes: 4 bus-ID: 2b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-5:3 chip-ID: 04f2:b67c class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x5a3d built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa
22.1.6 direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.60-1-lts running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
Local Storage: total: 505.84 GiB used: 29.99 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 3L1QEXF7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.9 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: 48.16 GiB size: 47.1 GiB (97.80%) used: 21.56 GiB (45.8%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 38.2 GiB size: 37.3 GiB (97.65%) used: 6.73 GiB
(18.0%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 263 Uptime: 16m wakeups: 1419 Memory: 7.33 GiB used: 3.32 GiB
(45.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1048 lib: 247
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.20
As a stated earlier, start by testing your memory.
Next go through the logs for errors. Although, hard freezes often don’t show up in the logs.
And only 8 GB of RAM. Can that be the issue?
Definitely could be.
I think it needs the kernel parameter ibt=off and then update grub. No drivers are being used for the nvidia mx250. Then check if nouveau open source is being used and or install the nvidia drivers.
It is a 10th gen mobile ice lake cpu and the same behaviour is seen with the LTS kernel. Why would ibt=off be needed here?
I’m not sure but it seems that all the users I see that have this issue of the drivers not showing nouveau or Nvidia even if they install the drivers. Then with the kernel parameter show drivers installed or nouveau. I think is worth trying and see if it helps with the freezing issue or not. ![]()
I thought this was just an nvidia issue requiring the ibt=off It is related to it only if the cpu is a certain Intel? ![]()
My understanding is it only applies to kernels 5.18 or later when you are using 11th or 12th gen intel cpus and nvidia drivers.
Set up SysRq and try recovery next time you get a freeze:
https://wiki.archlinux.org/title/Keyboard_shortcuts#Kernel_(SysRq)
Is 8GB of swap memory enough? Also I didn’t have freezes on Manjaro…
Yes this is certainly enough.
How much swap did you have with Manjaro?
I didn’t have any
I reinstalled the system with 8bg swap memory, but I’m still getting freezes. Should I go with the -b or -n option?
Why don’t you run a test first.
nvidia-installer-dkms -t
Show the output of this.
Edit: If the test runs without error i would install the nvidia drivers first.
Then see what happens on a reboot. Does it boot properly and are the nvdia drivers installed? I think i would still use the kernel parameter ibt=off also. But you could try it first without. See what it shows for drivers after.
inxi -Ga
I don’t know how to set the kernel parameter ibt = off, but so far I had no freeze. I assume the nvidia driver solved the problem. Also 1.5GB is used from swap memory, so probably both were needed.
Here is the ouptut for inxi -Ga command:
I see the drivers are installed for nvidia and showing up so i don’t think you need the kernel parameter anyway. It is running on Intel graphics. If you wanted to use nvidia graphics then you need some method to switch such as optimus-manager or some other. Hopefully no more freezing maybe?
