You can test it with command
sudo pacman -S mesa
but only if you have mesa already installed. Alternative tester package could be e.g. the kernel (linux ?) that you are currently using.
sudo pacman -S mesa
Perfect. Reinstalled Mesa, reboot pop-up appeared. Thanks, again!
Thanks for testing and reporting! ![]()
i have this after :
yay -Qdt
eos-reboot-recommended 26.1-1
Version 26.1-1 includes a fix for a minor unlikely corner case.
Edit: it still may be registered as a dependency.
Edit2: sudo pacman -D --asexplicit eos-reboot-recommended to change it.
Hard to say , because I can’t read the setting at the bottom that reads reboot expire time , the way I understand it you should be using that setting.
As an example, you likely made the following kind of changes in file
/etc/eos-reboot-recommended.conf:
REBOOT_NOTIFICATION_USER=micheln
REBOOT_EXPIRE_TIME=5
It’s set like this and it’s working fine ![]()
REBOOT_NOTIFICATION_USER="michel"
REBOOT_EXPIRE_TIME="10"
The quotes are included
