Endeavouros-mirrorlist could not be read?
I type yay into terminal to update and get this
[christopher67@EndeavourOS ~]$ yay
 -> exit status 1
error: config file /etc/pacman.d/endeavouros-mirrorlist could not be read: No such file or directory
error parsing '/etc/pacman.conf'
I even tried to update EOS Mirrors from the Welcome app and get this
==> eos-rankmirrors: error: no local /etc/pacman.d/endeavouros-mirrorlist found, please install package 'endeavouros-mirrorlist'.
Press ENTER to close this window:
endeavouros-mirrorlist is still installed :thinking:
It looks like the file was deleted somehow.
You can recreate it fairly easily.
Save the contents of the below link to /etc/pacman.d/endeavouros-mirrorlist
https://raw.githubusercontent.com/endeavouros-team/PKGBUILDS/master/endeavouros-mirrorlist/endeavouros-mirrorlist
All these sound strange.
Try with pacman and post terminal output :
pacman -Q endeavouros-mirrorlist
sudo pacman -Syu
@dalto
getting same errors
If you are still getting an error that the file is missing after putting the file there, you must have a typo somewhere.
@petsam
[christopher67@EndeavourOS ~]$ pacman -Q endeavouros-mirrorlist
[christopher67@EndeavourOS ~]$ sudo pacman -Syu
[sudo] password for christopher67:
:thinking:
What does ls -l /etc/pacman.d show?
Ok i figured it out, my endeavouros-mirrorlist was named endeavouros-mirrorlist.2023.05.02-21.27.38 For some reason, changed it back to endeavouros-mirrorlist and saved what you told me to and re updated EOS mirrors and all is great now.
Thanks!
looks like caused by a failed mirrorlist rank/update… not completed…
