Hi!
I have researched and not found a solution.
I have createte a usb flash boot media via rufus, i guess i chosed GPT. And I guess it was ISO Mode (How to check?).
My hardware:
- XMG NEO 15, XNE15E20, Nvidia RTX 2070 Refresh
- ASUS VG27AQ, external monitor, at the moment portrait mode, that’s why i have to rotate to left in linux settings.
My external monitor is not set in the correct direction, so I have to rotate it in settings.
After I set Rotation to left in Display settings (external screen) I get pixel errors, the mouse arrow moves in correct directions, but when I move folder or windows from laptop screen to my external screen they move not accordingly correctly in directions. Additionally I can only use about the half of the screen, because the windows begin to dissappear, see photos.
I booted with both EndeavourOS x86_64 UEFI Default and EndeavourOS x86_64 UEFI Nvidia (latest cards only), same issues.
- UEFI Default mode, rotate screen to left, result: https://ibb.co/n3j5pCk
- UEFI Nvidia (latest cards only), directly after boot: https://ibb.co/zbP80Tn
EndeavourOS version: atlantisNeo-21-5
xrandr:
Screen 0: minimum 8 x 8, current 3360 x 2560, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 240.00*+ 60.00
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
DP-1-1 connected 1440x2560+1920+0 left (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+ 120.00 99.95
1920x1440 85.00 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 120.00 100.00 119.88 59.97 59.96 60.00 60.00 50.00 59.94 59.93
1600x1200 85.00 75.00 70.00 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 60.00 50.00 59.94 59.74
1440x576 50.00
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
1440x480 60.00 59.94
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 75.00 72.81 75.00 66.67 60.00 59.94
720x405 59.51 58.99
720x400 85.04 70.08
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
eDP-1-2 disconnected (normal left inverted right x axis y axis)
Thx!
