Hey. I’ll apoligize if bad english ![]()
I have switched 2/3 weeks ago from LinuxMint 20.3 to EndeavourOS and I’m getting great with the distro.
The problem that makes me kinda unconfortable it’s the amount of RAM that eos keeps eating,
I don’t have any DE installed, like KDE, GNOME, XFCE, etc.
I have installed only i3wm from the installer and that’s it, but i mainly use DWM that i patched.
When i log in to DWM, the RAM used reach to ~849/950MB on idle, which is double compared to when i was using Linuxmint that was like ~489/502MB. I have noticed that when i open brave-browser and Discord, then quit both, the RAM reach to 1,3GB and on Mint it was ~703MB.
Once i was using Dolphin emulator for playing a Wii game with only discord opened and Xorg was keeping allocating memory, even after closing the emulator and discord, until it made the whole OS crash. hope i can kinda return to the old memory usage
for example now, I had only brave-browser opened, and when i closed it, the RAM used was 2,4GB
My system:
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet Desktop: dwm v: 6.4 vt: 1 dm: 1: LightDM v: 1.32.0
note: stopped 2: SDDM note: stopped Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Micro-Star model: PRO B550M-P GEN3 (MS-7D95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.22
date: 08/04/2022
Info: 6-core model: AMD Ryzen 5 5500 bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1058 high: 3197 min/max: 400/4267 cores: 1: 2913 2: 400
3: 400 4: 400 5: 400 6: 3197 7: 400 8: 400 9: 400 10: 400 11: 2991 12: 400
bogomips: 86235
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 arch: Turing pcie: speed: 2.5 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 10:00.0
chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: Picom v: git-b700a driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: HP V22e
serial: <filter> res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 30:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: down mac: <filter>
IF-ID-1: enp22s0f0u9 state: unknown speed: -1 duplex: half mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Huawei AUM-L29 driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-9:5 chip-ID: 12d1:108a class-ID: 0a00
serial: <filter>
Local Storage: total: 912.89 GiB used: 298.92 GiB (32.7%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S500G size: 465.76 GiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SBI02102
temp: 30.9 C scheme: GPT
ID-2: /dev/sda vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB
type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 tech: SSD serial: <filter>
fw-rev: 3202 scheme: GPT
ID-1: / size: 438.08 GiB used: 298.92 GiB (68.2%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 998 MiB used: 288 KiB (0.0%) fs: vfat dev: /dev/sda1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 39.8 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
Repos:
Packages: 1482 pm: pacman pkgs: 1475 pm: flatpak pkgs: 7
Active pacman repo servers in: /etc/pacman.d/endeavouros-mirrorlist
1: https://mirror.moson.org/endeavouros/repo/$repo/$arch
2: https://de.freedif.org/EndeavourOS/repo/$repo/$arch
3: https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch
4: https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
5: https://md.mirrors.hacktegic.com/endeavouros/repo/$repo/$arch
6: https://mirror.albony.xyz/endeavouros/repo/$repo/$arch
7: https://mirror.archlinux.tw/EndeavourOS/repo/$repo/$arch
8: https://mirror.freedif.org/EndeavourOS/repo/$repo/$arch
9: https://endeavour.remi.lu/repo/$repo/$arch
10: https://mirrors.gigenet.com/endeavouros/repo/$repo/$arch
11: https://fastmirror.pp.ua/endeavouros/repo/$repo/$arch
12: https://fosszone.csd.auth.gr/endeavouros/repo/$repo/$arch
13: https://mirror.funami.tech/endeavouros/repo/$repo/$arch
14: https://mirrors.nguyenhoang.cloud/endeavouros/repo/$repo/$arch
15: https://mirrors.nxtgen.com/endeavouros-mirror/repo/$repo/$arch
16: https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch
17: https://mirrors.jlu.edu.cn/endeavouros/repo/$repo/$arch
18: https://mirror.jingk.ai/endeavouros/repo/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: https://archmirror.it/repos/$repo/os/$arch
2: https://archlinux.mirror.server24.net/$repo/os/$arch
3: https://geo.mirror.pkgbuild.com/$repo/os/$arch
Processes: 278 Uptime: 2h 12m wakeups: 0 Memory: total: 16 GiB
available: 15.51 GiB used: 2.91 GiB (18.8%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: st
inxi: 3.3.30
sudo systemd-analyze blame
3.172s dev-ttyS23.device
3.172s sys-devices-platform-serial8250-tty-ttyS23.device
3.172s dev-ttyS24.device
3.172s sys-devices-platform-serial8250-tty-ttyS24.device
3.171s sys-devices-platform-serial8250-tty-ttyS22.device
3.171s dev-ttyS22.device
3.170s sys-devices-platform-serial8250-tty-ttyS25.device
3.170s dev-ttyS25.device
3.170s dev-ttyS27.device
3.170s sys-devices-platform-serial8250-tty-ttyS27.device
3.170s sys-devices-platform-serial8250-tty-ttyS28.device
3.170s dev-ttyS28.device
3.169s dev-ttyS29.device
3.169s sys-devices-platform-serial8250-tty-ttyS29.device
3.169s sys-devices-platform-serial8250-tty-ttyS3.device
3.169s dev-ttyS3.device
3.169s dev-ttyS11.device
3.169s sys-devices-platform-serial8250-tty-ttyS11.device
3.169s dev-ttyS30.device
3.169s sys-devices-platform-serial8250-tty-ttyS30.device
3.168s dev-ttyS12.device
3.168s sys-devices-platform-serial8250-tty-ttyS12.device
3.168s dev-ttyS26.device
3.168s sys-devices-platform-serial8250-tty-ttyS26.device
3.168s sys-devices-platform-serial8250-tty-ttyS10.device
3.168s dev-ttyS10.device
3.168s sys-devices-platform-serial8250-tty-ttyS5.device
3.168s dev-ttyS5.device
3.168s sys-devices-platform-serial8250-tty-ttyS4.device
3.168s dev-ttyS4.device
3.167s dev-ttyS14.device
3.167s sys-devices-platform-serial8250-tty-ttyS14.device
3.167s sys-devices-platform-serial8250-tty-ttyS15.device
3.167s dev-ttyS15.device
3.167s dev-ttyS6.device
3.167s sys-devices-platform-serial8250-tty-ttyS6.device
3.167s sys-devices-platform-serial8250-tty-ttyS7.device
3.167s dev-ttyS7.device
3.166s dev-ttyS31.device
3.166s sys-devices-platform-serial8250-tty-ttyS31.device
3.166s dev-ttyS1.device
3.166s sys-devices-platform-serial8250-tty-ttyS1.device
3.165s dev-ttyS9.device
3.165s sys-devices-platform-serial8250-tty-ttyS9.device
3.165s sys-devices-platform-serial8250-tty-ttyS8.device
3.165s dev-ttyS8.device
3.165s sys-devices-platform-serial8250-tty-ttyS13.device
3.165s dev-ttyS13.device
3.164s dev-ttyS16.device
3.164s sys-devices-platform-serial8250-tty-ttyS16.device
3.164s sys-devices-platform-serial8250-tty-ttyS19.device
3.164s dev-ttyS19.device
3.163s dev-ttyS18.device
3.163s sys-devices-platform-serial8250-tty-ttyS18.device
3.163s sys-devices-platform-serial8250-tty-ttyS2.device
3.163s dev-ttyS2.device
3.163s sys-devices-platform-serial8250-tty-ttyS17.device
3.163s dev-ttyS17.device
3.162s dev-ttyS20.device
3.162s sys-devices-platform-serial8250-tty-ttyS20.device
3.162s sys-devices-platform-serial8250-tty-ttyS21.device
3.162s dev-ttyS21.device
3.157s sys-module-configfs.device
3.152s dev-ttyS0.device
3.152s sys-devices-pnp0-00:05-tty-ttyS0.device
3.042s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971\x2dpart4.device
3.042s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971_1\x2dpart4.device
3.042s dev-disk-by\x2duuid-6EA28518A284E5C5.device
3.042s dev-nvme0n1p4.device
3.042s dev-disk-by\x2ddiskseq-1\x2dpart4.device
3.042s dev-disk-by\x2dpath-pci\x2d0000:2b:00.0\x2dnvme\x2d1\x2dpart4.device
3.042s dev-disk-by\x2did-nvme\x2deui.00000000000000000026b7784e129715\x2dpart4.device
3.042s sys-devices-pci0000:00-0000:00:02.2-0000:2b:00.0-nvme-nvme0-nvme0n1-nvme0n1p4.device
3.042s dev-disk-by\x2dpartuuid-51b16819\x2d7370\x2d4493\x2db936\x2d98ecda09f9d1.device
3.040s sys-devices-pci0000:00-0000:00:02.2-0000:2b:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device
3.040s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971_1\x2dpart2.device
3.040s dev-disk-by\x2dpath-pci\x2d0000:2b:00.0\x2dnvme\x2d1\x2dpart2.device
3.040s dev-disk-by\x2ddiskseq-1\x2dpart2.device
3.040s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971\x2dpart2.device
3.040s dev-disk-by\x2dpartlabel-Microsoft\x5cx20reserved\x5cx20partition.device
3.040s dev-nvme0n1p2.device
3.040s dev-disk-by\x2dpartuuid-e15514f6\x2d4ea8\x2d44fe\x2d84c2\x2dd7a35f4e223b.device
3.040s dev-disk-by\x2did-nvme\x2deui.00000000000000000026b7784e129715\x2dpart2.device
3.039s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971_1\x2dpart3.device
3.039s dev-disk-by\x2dpath-pci\x2d0000:2b:00.0\x2dnvme\x2d1\x2dpart3.device
3.039s sys-devices-pci0000:00-0000:00:02.2-0000:2b:00.0-nvme-nvme0-nvme0n1-nvme0n1p3.device
3.039s dev-disk-by\x2did-nvme\x2deui.00000000000000000026b7784e129715\x2dpart3.device
3.038s dev-nvme0n1p3.device
3.038s dev-disk-by\x2ddiskseq-1\x2dpart3.device
3.038s dev-disk-by\x2dpartuuid-6580529e\x2d9e93\x2d456a\x2d92a3\x2db70934936e0c.device
3.038s dev-disk-by\x2duuid-7CDA3609DA35BFE6.device
3.038s dev-disk-by\x2dpartlabel-Basic\x5cx20data\x5cx20partition.device
3.038s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971\x2dpart3.device
3.037s sys-devices-pci0000:00-0000:00:02.2-0000:2b:00.0-nvme-nvme0-nvme0n1.device
3.037s dev-nvme0n1.device
3.037s dev-disk-by\x2did-nvme\x2deui.00000000000000000026b7784e129715.device
3.037s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971_1.device
3.037s dev-disk-by\x2dpath-pci\x2d0000:2b:00.0\x2dnvme\x2d1.device
3.037s dev-disk-by\x2ddiskseq-1.device
3.037s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971.device
3.037s dev-nvme0n1p1.device
3.037s dev-disk-by\x2ddiskseq-1\x2dpart1.device
3.037s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971_1\x2dpart1.device
3.037s dev-disk-by\x2dpartuuid-57307908\x2d50e7\x2d48c2\x2da340\x2d9a6b96d8dca8.device
3.037s dev-disk-by\x2did-nvme\x2deui.00000000000000000026b7784e129715\x2dpart1.device
3.037s dev-disk-by\x2duuid-7C34\x2dCC4C.device
3.037s dev-disk-by\x2did-nvme\x2dKINGSTON_SNV2S500G_50026B7784E12971\x2dpart1.device
3.037s dev-disk-by\x2dpartlabel-EFI\x5cx20system\x5cx20partition.device
3.037s dev-disk-by\x2dpath-pci\x2d0000:2b:00.0\x2dnvme\x2d1\x2dpart1.device
3.037s sys-devices-pci0000:00-0000:00:02.2-0000:2b:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device
2.671s dev-sda1.device
2.671s sys-devices-pci0000:00-0000:00:08.1-0000:30:00.4-usb6-6\x2d1-6\x2d1:1.0-host6-target6:0:0-6:0:0:0-block-sda-sda1.device
2.671s dev-disk-by\x2did-wwn\x2d0x500a0751e4f5badd\x2dpart1.device
2.670s dev-disk-by\x2duuid-2AE2\x2dCF4F.device
2.670s dev-disk-by\x2did-ata\x2dCT480BX500SSD1_2106E4F5BADD\x2dpart1.device
2.670s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusbv3\x2d0:1:1.0\x2dscsi\x2d0:0:0:0\x2dpart1.device
2.670s dev-disk-by\x2dpartuuid-0ce4ea94\x2d85df\x2d44e3\x2dbebf\x2dcea5644deb93.device
2.670s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusb\x2d0:1:1.0\x2dscsi\x2d0:0:0:0\x2dpart1.device
2.670s dev-disk-by\x2ddiskseq-2\x2dpart1.device
2.670s dev-disk-by\x2did-usb\x2dJMicron_Tech_210654652144\x2d0:0\x2dpart1.device
2.670s dev-sda2.device
2.669s dev-disk-by\x2did-usb\x2dJMicron_Tech_210654652144\x2d0:0\x2dpart2.device
2.669s dev-disk-by\x2ddiskseq-2\x2dpart2.device
2.669s dev-disk-by\x2dlabel-endeavouros.device
2.669s dev-disk-by\x2dpartuuid-cb91a95c\x2dfb54\x2d4e76\x2d8716\x2d5f1ac8afc037.device
2.669s dev-disk-by\x2dpartlabel-endeavouros.device
2.669s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusb\x2d0:1:1.0\x2dscsi\x2d0:0:0:0\x2dpart2.device
2.669s dev-disk-by\x2did-ata\x2dCT480BX500SSD1_2106E4F5BADD\x2dpart2.device
2.669s sys-devices-pci0000:00-0000:00:08.1-0000:30:00.4-usb6-6\x2d1-6\x2d1:1.0-host6-target6:0:0-6:0:0:0-block-sda-sda2.device
2.669s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusbv3\x2d0:1:1.0\x2dscsi\x2d0:0:0:0\x2dpart2.device
2.669s dev-disk-by\x2did-wwn\x2d0x500a0751e4f5badd\x2dpart2.device
2.669s dev-disk-by\x2duuid-a9564977\x2d6fc3\x2d43ab\x2d9471\x2db757f4f79ca6.device
2.652s sys-devices-pci0000:00-0000:00:08.1-0000:30:00.4-usb6-6\x2d1-6\x2d1:1.0-host6-target6:0:0-6:0:0:0-block-sda.device
2.652s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusbv3\x2d0:1:1.0\x2dscsi\x2d0:0:0:0.device
2.652s dev-disk-by\x2dpath-pci\x2d0000:30:00.4\x2dusb\x2d0:1:1.0\x2dscsi\x2d0:0:0:0.device
2.652s dev-sda.device
2.652s dev-disk-by\x2did-wwn\x2d0x500a0751e4f5badd.device
2.652s dev-disk-by\x2ddiskseq-2.device
2.652s dev-disk-by\x2did-usb\x2dJMicron_Tech_210654652144\x2d0:0.device
2.652s dev-disk-by\x2did-ata\x2dCT480BX500SSD1_2106E4F5BADD.device
1.326s eos-reboot-required.service
736ms initrd-switch-root.service
417ms firewalld.service
387ms NetworkManager.service
228ms systemd-tmpfiles-clean.service
202ms systemd-tmpfiles-setup.service
200ms systemd-journal-flush.service
194ms systemd-udev-trigger.service
183ms ldconfig.service
179ms user@1000.service
151ms systemd-tmpfiles-setup-dev-early.service
150ms lvm2-monitor.service
131ms systemd-remount-fs.service
125ms power-profiles-daemon.service
119ms libvirtd.service
116ms systemd-random-seed.service
115ms systemd-modules-load.service
112ms systemd-binfmt.service
103ms systemd-journald.service
88ms modprobe@fuse.service
87ms systemd-sysctl.service
79ms upower.service
75ms dracut-cmdline.service
72ms avahi-daemon.service
69ms udisks2.service
68ms systemd-logind.service
67ms modprobe@drm.service
61ms polkit.service
58ms systemd-sysusers.service
53ms systemd-udevd.service
49ms systemd-fsck@dev-disk-by\x2duuid-2AE2\x2dCF4F.service
47ms swapfile.swap
43ms systemd-journal-catalog-update.service
42ms dracut-shutdown.service
42ms systemd-oomd.service
41ms systemd-timesyncd.service
37ms kmod-static-nodes.service
34ms systemd-vconsole-setup.service
31ms alsa-restore.service
31ms cockpit.socket
30ms uresourced.service
30ms systemd-machined.service
30ms systemd-user-sessions.service
30ms boot-efi.mount
29ms user-runtime-dir@1000.service
28ms dbus-broker.service
27ms NetworkManager-wait-online.service
26ms modprobe@loop.service
25ms systemd-tmpfiles-setup-dev.service
24ms sys-fs-fuse-connections.mount
21ms systemd-update-utmp.service
21ms systemd-fsck-root.service
21ms proc-sys-fs-binfmt_misc.mount
18ms initrd-cleanup.service
18ms dev-hugepages.mount
17ms dev-mqueue.mount
17ms sys-kernel-debug.mount
16ms sys-kernel-tracing.mount
14ms cockpit-motd.service
13ms systemd-update-done.service
11ms initrd-parse-etc.service
5ms initrd-udevadm-cleanup-db.service
5ms rtkit-daemon.service
5ms cni-dhcp.socket
2ms modprobe@configfs.service
2ms modprobe@dm_mod.service
1ms tmp.mount
