Is there an EndeavourOS install for WSL2
No
Welcome to the forum though.
I notice that there are a couple of GitHub pages about installing Arch on WSL. I wonder if it would be possible to do that and then āupgradeā to EndeavourOS.
Presumably if that works, then adding EndeavourOS repos (and desired apps) to the build should work fine. COmpletely untested here though - my last good Windows was MEā¦
Welcome to the forum @mhlr
Iāve said it before, and Iāll say it again - thereās no point in having anything other than plain Arch in WSL.
You donāt need drivers, you donāt need tooling, you donāt need default desktop themes and settings. All you need is a way to install packages and run applications, both of which plain Arch will give you without any mess or fuss.
