I’m unsure in what section to post this really, hopefully it’s okay here.
When running yay, I get the following error message: error: failed retrieving file 'endeavouros.db' from ca.gate.endeavouros.com : Connection timeout after 10000 ms
This is the entire terminal output:
❯ yay
[sudo] password for smokus:
core is up to date
extra is up to date
community 6,7 MiB 3,83 MiB/s 00:02 [----------------------------------------] 100%
multilib is up to date
endeavouros is up to date
there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
-> Flagged Out Of Date AUR Packages: libreoffice-extension-languagetool
Can I do something about it or simply wait it out?
It has never happened before.
I am about to jump into a meeting so can’t be more helpful but I would quickly point out that it is the EOS mirror that needs changing, not the Arch mirror.
When you install EOS, will it automatically rank mirrors (for both, Arch and EOS) or does the user need to do this manually?
(reason for asking: It’s always the first mirror in your mirror-list that is being utilized by pacman (unless that one “fails” and the next one is used). Assuming that a lot of users do not do this, it will put a big burden on ca.gate.endeavouros.com since that is the first one in the “default” list…)
As far as I know, it doesn’t do it automatically. Users have to do it manually using reflector-simple.
Additionally, there should be an option to rank eos-mirrors when eos-mirrorlist is updated.
Currently Arch mirrors will be ranked, but EOS mirrors not.
Looks like it is now missing after some mirror changes, so we need to make this change as well.
I updated my system (sudo pacman -Syyu) on July 28, 2022 and not problem updating. But then I rean the same update command on July 30, 2022 and I was able to replicate the same error reported abobe.
As recommainded I ran " eos-rankmirrors" and the problem was fixed.
