Is it fine to use the endeavour os calamares installer for btrfs installation with encryption using the latest release or do I have to follow this guide to get the installation done?
guide link : https://discovery.endeavouros.com/encrypted-installation/btrfsonluks-verbose-version/2021/03/
You can just use the installer to get an encrypted btrfs installation.
Does it work with swap + hibernate as well i.e swap with hibernate option in calamares.
Selecting erase disk, btrfs, swap with hibernate and encryption.
Does the combo work fine?
I have not personally tried that combination but I would think that it would be fine.
There is one easy way to find out. ![]()
