Endeavour OS fresh install with refind as bootloader
Hello,
I have performed a fresh install of Endeavour OS, in parallel with Winblowz 11. Because I also wanted a @snapshots subvolume, I edited the file /etc/calamares/modules/mount.conf on the USB disk and added
- mountPoint: /.snapshots
  subvolume: /@snapshots
as shown in Changing ISO btrfs subvolumes, as I discovered later.
I also wanted to directly install refind as a bootloader instead of the two default options efibootmgr and Grub. I have taken a look at Calamares bootloader github page, then edited the /etc/calamares/modules/bootlader.conf file, and commented line 13
<# efiBootLoaderVar: “packagechooser_packagechoosersr”/>
and inserted
efiBootLoader: “refind”
I chose refind as the bootloader, the installation went smooth until the bootloader install step, and it returned an error code 137 (I hope I remember well). The install log can be seen at Error code 1
I tried once more to reinstall, I edited again the /etc/calamares/modules/bootlader.conf file as done previously, but I chose efibobotmgr as the bootloader instead of refind. I have reproduced the error code, and the install log is available at Error code 2.
I performed the 3rd installation, left the bootloader.conf file untouched, chose efibootmgr and that was it. I could not directly boot into Endeavour OS under these circumstances, I could only boot after installing refind in Winblowz, which has “seen” the linux-zen img.
Is there any way to directly install refind? What am I missing? If I would have booted in arch-chroot mode after the EndeavpurOS installation, was it a better idea to install refind in such manner?
I would like to thank the Endeavour community and programmers, the system saves you a considerable amount of time with respect to a fresh ArchLinux install.
Thank you for your help,
Bogdan
Set bootloader to none during the install and then after the install chroot into the install, mount the EFI partition and install(and configure) refind.
Also check and ensure that eos-dracut is installed.
Thank you @dalto
Another way you could set this up would be to add refind to ~/user_pkglist.txt, then set refind-install as a command in ~/user_commands.bash before starting the installation.
https://discovery.endeavouros.com/installation/customizing-the-endeavouros-install-process/
If you prefer to use a manual boot stanza, you can add it with a heredoc in user_commands.bash.
Thank you very much, it is an option that can be easily implemented.
Actually user_commands.bash can handle it without user_pkglist.txt.
You would need to create a command that can install it if you wanted to add it to user_commands.bash without using user_pkglist.txt. For example:
pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout refind
You can’t just add a list of packages to user_commands.bash like you would with user_pkglist.txt.
