Encrypted volume install with Dracut instead of mkinitcpio
I am following the guide here to set up an encrypted system: https://discovery.endeavouros.com/encrypted-installation/lvmonluks/2021/03/
Everything is going great, however the guide references mkinitcpio instead of dracut in step 11. Is there anything that needs to be done in the dracut config file?
Hardware information:
https://0x0.st/HZgb.txt
Boot log:
https://0x0.st/HZgc.txt
dracut should automatically detect the need for lvm and resume as long as your build your boot images with those in your running system.
I left dracut alone in step 11.
I’m also running into an issue with dracut in step 14.
I followed the step but omitted mkinitcpio -p linux.
I followed the remaining steps and when I boot, from my new install, it stops at Reached target Basic System.
I must be missing something here, any advice?
You needed to replace that step with sudo dracut-rebuild to build the new boot images.
That did the trick, thanks!
I also found some issues in my grub config file that I corrected.
