Enabling Swap Memory in Fstab
I installed Endeavour OS Linux and when I checked fstab I didn’t find swap enabled. I have 8GB of memory and I use a mechanical disk. What I did was enable swap in the fstab as well. Is there any problem with this configuration?
In many cases you don’t need to add your swap to /etc/fstab, it will be enabled automatically.
It shouldn’t hurt anything to add it though.
Thank you so much.
