I had somehow added a partition to my system that was labeled CentOS. It just was empty and I went ahead and deleted it and then resized my system and now I boot into emergency mode. I have no access to another system and basically everything I look up everyone says today boot live USB. I don’t have that option.
Looking at the picture, it looks like your system has got to the OS, but just won’t load. That much is a “positive” thing. At least it recognises it.
PS: In the future, and after this is resolved somehow, always have a live ISO on a USB/CD that isn’t used for anything but that. Every time there is a new ISO for your OS of choice, download it, test it, and if it works properly (meaning you can boot into it), then you can replace the old ISO.
Treat it like part of your system maintenance routine.
That doesn’t really affect whether you need a BIOS update.
Try this (it may not work):
nano /etc/pacman.conf
Based on the errors you’ve shown (in the second set of images), there seems to be a problem with your OS being able to communicate with your hardware. The first set seems like a failed attempt from pacman to reach the necessary repos.
Anyway, for the most part, you’ll just have to wait for someone with more experience and knowledge in this area.
it’s the first picture that’s alarming. all the can’t mount/fstab fubar’d stuff. that suggests a boot problem and the second one I’ve seen today.
the second pic not good because @anon93652015 is right, you need to do this stuff because mirror craziness.
fix the mirrors, get proper updates, the boot mount fixes itself? sometimes.
reflector --protocol https --verbose --latest 25 --sort rate --save /etc/pacman.d/mirrorlist
yay -Syyu
eos-rankmirrors --verbose
yay -Syyu
if you can’t get a terminal while booting (ctrl+F-key-something-try-them-all-til you get terminal) then nothing I say here matters. I see a terminal in the first pic I think.
Ok thanks everyone. Iam going to try all this. I am able to login as root through emergency mode but other then that no other terminal but I will try what you. Said.
And I am downloading the android software as we speak thanks again
So I have a the ability to not only access terminal but running
Startxfce4 opens Xfce4 desktop nly network manager isn’t running. How can I get a conneçifon
