You have the bottom of the case off. How many m.2 drives are in it. One or two? Your original post with lsblk command only shows one drive. Not sure why it was showing two drives? I don’t see any settings in the bios that would indicate it is a raid setup? The bios hardly has any settings that I can see unless there’s more pages?
Your UEFI basically has very little in the way of settings. Did you ever enable TPM and remove the keys then turn off and try again to turn off secure boot.
Edit: I think you did this before. Anyway is it possible for you to boot on another live usb such as PopOs? If you can do that and maybe i can get a look at some more info such as the hardware.
Also i see here are items below the screenshot you posted that allow you to set the default Bios settings. This will most likely have secure boot on and maybe TPM also. Try to disable secure boot but leave TPM on after setting the defaults. See if any different.
I just don’t have enough information about the hardware that you have. I did find this about the error message you are showing but it is different hardware. Some laptops have special keys such as Ctrl s to open a certain screen in the bios to get into other settings that you don’t see normally. I don’t know on your hardware how it is set up? If it is possible to get it to boot then it would be nice to see the hardware. You may have to install inxi first. Then inxi -Faz --no-host
Here is the info regarding that error but it is on a zenbook.
Have you set an administrator password? A quick Google search suggests you might need to do this before you can disable Secure Boot in some implementations of the InsydeH20 BIOS.
If you do, make sure that you can remember what password you set. A forgotten BIOS password can be difficult (and sometimes essentially impossible) to reset.
I don’t see anything odd about the hardware. How did you manage to get it to boot? Is there a Bios update for this laptop? Not sure what you have on this laptop but if you got it booted on PopOS it might be worth trying to get whatever files off you want saved.
I managed to boot into EOS live ISO (newest version). will immediately pull out all files I need. besides this, anything I can try to make it work without doing a fresh install?
EDIT: if I navigate into /boot/efi Is completely empty
Since it seemed from your efibootmgr that you don’t have an efi boot entry for enos, I would at least try reinstalling the bootloader from the live iso.
You would need to look at the following for how to chroot:
