Echo in microphone
Hi! I have echo when I speak. And I have this problem when I use REDMI Buds 8 Lite (headset) or Ryzen HD Audio Controller Analog Stereo. Monitor doesn’t work. And I have this problem in zoom, google meet, discord, viber and in different browsers like mozilla, chrome etc. I download audio-recorder and with REDMI Buds 8 Lite it works fine, with Ryzen HD Audio Controller Analog Stereo there are noises.
Comment: In Windows sound works fine with internal micro or with headset.
I can give you additional info if you need.
Sorry for my English :sweat_smile:
IdeaPad_Gaming_3_15ARH05_Spec.pdf (557.4 KB)
You could try easyeffects that seems to have a echo canceller.
I tried when I was in Ubuntu and it doesn’t work :sweat_smile:
Ubuntu and Arch are very different Just because something doesn’t work in one doesn’t mean it wont work in another.
Okay, I installed easy effects, set default input (my headset):
in ‘Input’ chose ‘Echo Canceller’:
When I create meeting in Google Meet (I selected my headset) and now nobody can’t hear me.
In volume → ‘Show virtual devices’ I have next micros:
What the problem might be?
I mean when I closed easy effect I can talk.
I don’t even have a microphone and wasn’t really chiming in to help only to point out that the 2 distro’s are very different. Arch is Rolling release with the latest and greatest. Ubuntu is yesterdays software. As far as your echo issue I have no idea. Maybe someone who is more familiar with your issue will chime in.
What happens if you select easy effects source in input/output ? Since you didn’t select them in your last 2 pictures.
