Easiest way to get ARM Archlinux
I have toyed with putting ARM Archlinux on RPI4 with USB SSD booting for a while. It’s very hard with many steps. Just found out about EndeavourOS for Arm and it’s trivial to install by comparison. Thanks to all those who developed this.
Jim, thank you for the feedback.
Installing ARM for RPi 4b will be even easier in a few days.
Pudge
@anon75994754
Don’t worry, if possible the old method will be maintained. In fact, we may call upon you to do a test PineBook Pro install.
Pudge
i no worry… only me + @lxnauta use Pinebook pro on forum . ( that i aware ) i + lxnauta have zero problem install from scratch.
think U miss understand my emoji.
No make work for your self , this direction Endeavouros go :+1: that cool
I can also can make pinebook pro test installs :slight_smile: but I also don’t know if anyone else in the EOS forum uses the pinebook pro.
