Hello,
My earbuds would connect to the laptop, but like title said there would be either no sound or sound for literally 1 second then gone, then I can hear sound again when it disconnects but then of course, it disconnects.
I’m dualbooting Windows and yes it works on Windows so it’s not a hardware problem. I have read through a lot of posts and there is one thing left I haven’t try which is using bt-dualboot, because of an error blocking me. But on a fresh install of EOS it does work, but after reboot no.
Can anyone help me with this? I’m new to Linux and Endeavour is the first OS (I know it’s stupid to run headlong into Arch-based at the start, but Linux is the platform for me to challenge myself and try new things with customization), so I don’t know how to diagnose my problems yet but I won’t mind digging in terminal and following instructions.
There are some logs in btmon though:
> HCI Event: User Confirmation Request (0x33) plen 10 #248 [hci0] 17.502822
Address: 41:42:1A:4B:8A:7F (OUI 41-42-1A)
Passkey: 982438
< HCI Command: User Confirmation Request Neg Reply (0x01|0x002d) plen 6 #249 [hci0] 17.502844
> HCI Event: Command Complete (0x0e) plen 10 #250 [hci0] 17.503196
User Confirmation Request Neg Reply (0x01|0x002d) ncmd 1
Status: Success (0x00)
> HCI Event: Simple Pairing Complete (0x36) plen 7 #251 [hci0] 17.503319
Status: Authentication Failure (0x05)
> HCI Event: Auth Complete (0x06) plen 3 #252 [hci0] 17.503434
Handle: 51 Address: 41:42:1A:4B:8A:7F (OUI 41-42-1A)
@ MGMT Event: Authentication Failed (0x0011) plen 8 {0x0001} [hci0] 17.503441
BR/EDR Address: 41:42:1A:4B:8A:7F (OUI 41-42-1A)
Status: Authentication Failed (0x05)
< ACL Data TX: Handle 51 flags 0x00 dlen 8 #253 [hci0] 17.503450
Channel: 110 len 4 [PSM 3 mode Basic (0x00)] {chan 1}
RFCOMM: Disconnect Mode (DM) (0x0f)
Address: 0x0d cr 0 dlci 0x03
Control: 0x1f poll/final 1
Length: 0
FCS: 0xd0
> ACL Data RX: Handle 3837 flags 0x02 dlen 16 #254 [hci0] 17.509158
Channel: 512 len 12 [PSM 0 mode Basic (0x00)] {chan 65535}
33 00 37 50 23 00 01 00 00 05 00 00 3.7P#.......
bluetoothd[880]: < ACL Data TX: Handle 51 flags 0x00 dlen 7 #255 [hci0] 34.097139
Channel: 111 len 3 [PSM 25 mode Basic (0x00)] {chan 2}
AVDTP: Start (0x07) Command (0x00) type 0x00 label 11 nosp 0
ACP SEID: 2
bluetoothd[880]: = profiles/audio/avdtp.c:cancel_request() Start: Connection timed out (110) 40.524275
bluetoothd[880]: < ACL Data TX: Handle 51 flags 0x00 dlen 7 #256 [hci0] 40.524295
AVDTP: Abort (0x0a) Command (0x00) type 0x00 label 12 nosp 0
ACP SEID: 2
bluetoothd[880]: = profiles/audio/avdtp.c:cancel_request() Abort: Connection timed out (110) 42.521665
< ACL Data TX: Handle 51 flags 0x00 dlen 12 #257 [hci0] 42.521787
L2CAP: Disconnection Request (0x06) ident 17 len 4
Destination CID: 116
Source CID: 68
< ACL Data TX: Handle 51 flags 0x00 dlen 12 #258 [hci0] 42.589238
L2CAP: Disconnection Request (0x06) ident 18 len 4
Destination CID: 113
Source CID: 67
< ACL Data TX: Handle 51 flags 0x00 dlen 12 #259 [hci0] 42.589304
L2CAP: Disconnection Request (0x06) ident 19 len 4
Destination CID: 111
Source CID: 66
< HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17 #260 [hci0] 45.546956
Transmit bandwidth: 8000
Receive bandwidth: 8000
Max latency: 13
Setting: 0x0003
Input Coding: Linear
Input Data Format: 1's complement
Input Sample Size: 8-bit
# of bits padding at MSB: 0
Air Coding Format: Transparent Data
Retransmission effort: Optimize for link quality (0x02)
Packet type: 0x0380
3-EV3 may not be used
2-EV5 may not be used
3-EV5 may not be used
> HCI Event: Command Status (0x0f) plen 4 #261 [hci0] 45.548521
Setup Synchronous Connection (0x01|0x0028) ncmd 1
> HCI Event: Encryption Key Refresh Complete (0x30) plen 3 #262 [hci0] 47.502098
Status: LMP Response Timeout / LL Response Timeout (0x22)
> HCI Event: Number of Completed Packets (0x13) plen 5 #263 [hci0] 47.504206
Num handles: 1
Count: 1
#253: len 8 (0 Kb/s)
Latency: 30000 msec (1-30000 msec ~15502 msec)
Channel: 110 [PSM 3 mode Basic (0x00)] {chan 1}
Channel Latency: 30000 msec (1-30000 msec ~15502 msec)
< ACL Data TX: Handle 51 flags 0x00 dlen 22 #264 [hci0] 47.504215
Channel: 110 len 18 [PSM 3 mode Basic (0x00)] {chan 1}
RFCOMM: Unnumbered Info with Header Check (UIH) (0xef)
Address: 0x13 cr 1 dlci 0x04
Control: 0xef poll/final 0
Length: 14
FCS: 0x65
0d 0a 2b 43 49 45 56 3a 20 32 2c 31 0d 0a 65 ..+CIEV: 2,1..e
> HCI Event: Number of Completed Packets (0x13) plen 5 #265 [hci0] 47.505586
Num handles: 1
Count: 1
#255: len 7 (0 Kb/s)
Latency: 13408 msec (1-30000 msec ~14455 msec)
Channel: 111 [PSM 25 mode Basic (0x00)] {chan 2}
Channel Latency: 13408 msec (2-13408 msec ~6207 msec)
> HCI Event: Number of Completed Packets (0x13) plen 5 #266 [hci0] 47.506707
Num handles: 1
Count: 1
#256: len 7 (0 Kb/s)
Latency: 6982 msec (1-30000 msec ~10218 msec)
Channel Latency: 6982 msec (2-13408 msec ~6094 msec)
> HCI Event: Number of Completed Packets (0x13) plen 5 #267 [hci0] 47.511834
Num handles: 1
Count: 1
#257: len 12 (0 Kb/s)
Latency: 4990 msec (1-30000 msec ~7604 msec)
> HCI Event: Number of Completed Packets (0x13) plen 5 #268 [hci0] 47.512956
Num handles: 1
Count: 1
#258: len 12 (0 Kb/s)
Latency: 4923 msec (1-30000 msec ~6264 msec)
> HCI Event: Number of Completed Packets (0x13) plen 5 #269 [hci0] 47.515587
Num handles: 1
Count: 1
#259: len 12 (0 Kb/s)
Latency: 4926 msec (1-30000 msec ~5595 msec)
> HCI Event: Number of Completed Packets (0x13) plen 5 #270 [hci0] 47.526588
Num handles: 1
Count: 1
#264: len 22 (8 Kb/s)
Latency: 22 msec (1-30000 msec ~2308 msec)
Channel Latency: 22 msec (1-30000 msec ~7762 msec)
> HCI Event: Disconnect Complete (0x05) plen 4 #271 [hci0] 47.726831
Handle: 3584
Reason: LMP Response Timeout / LL Response Timeout (0x22)
> HCI Event: Disconnect Complete (0x05) plen 4 #272 [hci0] 47.727074
@ MGMT Event: Device Disconnected (0x000c) plen 8 {0x0001} [hci0] 47.727081
Reason: Unspecified (0x00)
bluetoothd[880]: = src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voi.. 47.727187
