Hello! On my PC, I have installed the main distro EndeavourOS on BTRFS, with /home
on ext4, Windows 10 on NTFS, and one partition dedicated for testing different distributions. The current testing distro is Archcraft Linux. Initially, when I installed Archcraft Linux on ext4, there were no issues - os-prober
in EndeavourOS could detect it, and there were no problems with GRUB.
However, when I attempted a new installation of Archcraft Linux on BTRFS, EndeavourOS’s GRUB could no longer detect it. Only EndeavourOS and Windows 10 were visible. The same issue occurred when using Archcraft’s GRUB - it couldn’t detect EndeavourOS.
I found that if I mount Archcraft in fstab
with the subvol
parameter set to subvol=/@
, os-prober
was able to detect Archcraft. However, attempting to boot into Archcraft from GRUB resulted in an error.
error: file '/boot/vmlinuz-linux' not found.
And this is my FSTAB file:
UUID=7071-6531 /boot/efi vfat fmask=0137,dmask=0027 0 2
UUID=6cff14c5-7e99-4a74-8820-818469c758e9 / btrfs subvol=/@,noatime,compress=zstd 0 0
UUID=6cff14c5-7e99-4a74-8820-818469c758e9 /var/cache btrfs subvol=/@cache,noatime,compress=zstd 0 0
UUID=6cff14c5-7e99-4a74-8820-818469c758e9 /var/log btrfs subvol=/@log,noatime,compress=zstd 0 0
UUID=5957b196-c33b-40d9-b083-1acac555be6f /home ext4 noatime 0 2
UUID=F8D005A1D00566EA /media/data ntfs noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=e25f324f-adb1-49f2-81b2-324d092b3ce8 /media/archcraft btrfs subvol=/@ 0 0
This is the section in my grub.cfg
file that pertains to Archcraft:
menuentry 'Archcraft (rolling) (on /dev/nvme0n1p5)' --class archcraft --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
insmod part_gpt
insmod btrfs
search --no-floppy --fs-uuid --set=root e25f324f-adb1-49f2-81b2-324d092b3ce8
linux /boot/vmlinuz-linux root=/dev/nvme0n1p5
initrd /boot/initramfs-linux.img
submenu 'Advanced options for Archcraft (rolling) (on /dev/nvme0n1p5)' $menuentry_id_option 'osprober-gnulinux-advanced-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
menuentry 'Archcraft (rolling) (on /dev/nvme0n1p5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-linux--e25f324f-adb1-49f2-81b2-324d092b3ce8' {
insmod part_gpt
insmod btrfs
Now if I manually (hard code) add these lines to grub.cfg
(taken from the original Archcraft grub.cfg
menuentry 'Archcraft Linux' --class archcraft --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
linux /@/boot/vmlinuz-linux root=UUID=e25f324f-adb1-49f2-81b2-324d092b3ce8 rw rootflags=subvol=@ quiet splash loglevel=3 udev.log_level=3 vt.global_cursor_default=0 splash
initrd /@/boot/initramfs-linux.img
submenu 'Advanced options for Archcraft Linux' --class recovery $menuentry_id_option 'gnulinux-advanced-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
menuentry 'Archcraft Linux, with Kernel: linux' --class archcraft --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
menuentry 'Archcraft Linux, with Kernel: linux (fallback initramfs)' --class archcraft --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
initrd /@/boot/initramfs-linux-fallback.img
menuentry 'Archcraft Linux, with Kernel: linux (recovery mode)' --class archcraft --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-recovery-e25f324f-adb1-49f2-81b2-324d092b3ce8' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
linux /@/boot/vmlinuz-linux root=UUID=e25f324f-adb1-49f2-81b2-324d092b3ce8 rw single rootflags=subvol=@
After last hard coding everything is working fine and appears to be in order. I believe that setting the correct mounting parameters in fstab
will resolve the issue, after which running sudo grub-mkconfig -o /boot/grub/grub.cfg
should finalize the configuration.
However, which parameter should be used correctly? Or is there something else that needs to be considered?
