Drivers for TPLINK wireless USB
Hi!. Just bought a TPLINK wireless USB adapter.
The model it’s TL-WN823N (V3)
On the oficial webpage drivers for Linux are shown, but it seems that only for kernel versions up to 4
.10
oficial page >> https://www.tp-link.com/ar/support/download/tl-wn823n/
i’ve checked for ways to get the drivers for arch linux, but a problem wth the kernel version seems to occur.
example #1,
yay RTL8192EU
Result:
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.15.10-arch1-1/build M=/home/argenisjimort/.cache/yay/rtl8192eu-git/src/rtl8192eu-linux-driver  modules
make[1]: *** /lib/modules/5.15.10-arch1-1/build: No such file or directory.  Stop.
make: *** [Makefile:2289: modules] Error 2
You can try the git package instead then.
yay -S rtl8192eu-git
Edit: You probably used the wrong command because of upper case.
Should be:
yay -S rtl8192eu
Edit: Both are in the AUR
[ricklinux@eos-kde ~]$ yay -Ss rtl8192eu
aur/rtl8192eu-git 118.1628c74-1 (+2 0.00)
    Drivers for the rtl8192eu chipset for wireless adapters (D-Link DWA-131).
aur/rtl8192eu 4.4.1-3 (+9 0.00) (Out-of-date: 2021-10-11)
    Driver for the Realtek8192eu chipset.
Sometimes it’s best to search with yay first using yay -Ss because the name of the file has to be accurate.
I assume you checked it had decent Linux support before buying it? :wink:
Yes indeedy, and making the search slightly less specific can also highlight useful options:
$ yay -Ss 8192EU
aur/8192eu-dkms-git r136.6a758d5-1 (+1 0.29)
    Driver for the Realtek 8192eu chipset (DKMS)
aur/rtl8192eu 4.4.1-3 (+9 0.00) (Out-of-date: 2021-10-12)
aur/8192eu-dkms 114.6d2705d-1 (+12 0.33) (Orphaned) (Out-of-date: 2021-01-31)
DKMS driver packages are much more likely to be useful compared to the others.
Sadly I made the mistake of not checking decent Linux support before buying.
Anyways, my 2 cents, lsub should show which drivers to use - apparently tp-link change internals without changing the model number.
$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 046d:082d Logitech, Inc. HD Pro Webcam C920
Bus 003 Device 004: ID 0557:2213 ATEN International Co., Ltd CS682 2-Port USB 2.0 DVI KVM Switch
Bus 003 Device 002: ID 0557:8021 ATEN International Co., Ltd Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2357:0120 TP-Link Archer T2U PLUS [RTL8821AU]  <<<<<<<<<<
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
So I had to install drivers for RTL8821AU
Always check the hardware info as it is the chip that matters. Sometimes the chip will even be a different vendor or as in your case a different version.
UPDATE #1:
I feel like i did’t explain the problem clearly enough.
i have tried to download all those drivers in many of the ways i’ve been suggested to.
The problems seems to be that the drivers only work up to a certain linux kernel version., as the error shown after tried to install any of them seems to suggest:
==> Starting pkgver()...
==> Starting build()...
==> ERROR: A failure occurred in build().
    Aborting...
 -> error making: rtl8192eu-git
You needed to install this one.
yay -S rtl8821au-dkms-git
tried this, and now this error occurs:
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
==> ERROR: Missing 5.15.11-arch2-1 kernel modules tree for module 8821au/5.12.5.2.r113.g40dde99.
Do you have it working or not?
Edit: Try this one
yay -S rtl88xxau-aircrack-dkms-git
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> ERROR: Missing 5.15.11-arch2-1 kernel modules tree for module rtl88xxau/r1174.3a6402e.
(3/3) Checking which packages need to be rebuilt
Okay…you have shown 3 different packages all not working? Are you running on the lts kernel or some other? Or are you not running the package install correctly?
Just press enter for each entry.
Do you have kernels headers installed? Do they match the kernel version?
What is the output of:
pacman -Q | grep linux
I believe i just have to accept the “linux compatible” usb wireless adapter i just bought doesnt work.
Even the oficial Tp-link webpage show drivers avaliable only up to 4.10
anyways, heres my linux kernel.
Current Kernel version:
$ uname -r
5.15.10-arch1-1
and here the installation process:
$ yay -S rtl88xxau-aircrack-dkms-git
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1]  rtl88xxau-aircrack-dkms-git-r1174.3a6402e-1
  1 rtl88xxau-aircrack-dkms-git      (Installed) (Build Files Exist)
==> Packages to cleanBuild?
:: PKGBUILD up to date, Skipping (1/0): rtl88xxau-aircrack-dkms-git
==> Diffs to show?
:: (1/1) Parsing SRCINFO: rtl88xxau-aircrack-dkms-git
==> Making package: rtl88xxau-aircrack-dkms-git r1174.3a6402e-1 (jue 30 dic 2021 21:50:51)
==> Retrieving sources...
  -> Updating rtl88xxau git repo...
Fetching origin
  -> Found dkms.conf
==> Validating source files with sha256sums...
    rtl88xxau ... Skipped
    dkms.conf ... Passed
==> Making package: rtl88xxau-aircrack-dkms-git r1174.3a6402e-1 (jue 30 dic 2021 21:51:10)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
Fetching origin
  -> Found dkms.conf
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Creating working copy of rtl88xxau git repo...
Cloning into 'rtl88xxau'...
done.
Switched to a new branch 'makepkg'
==> Sources are ready.
==> Making package: rtl88xxau-aircrack-dkms-git r1174.3a6402e-1 (jue 30 dic 2021 21:51:44)
==> WARNING: Using existing $srcdir/ tree
 -> rtl88xxau-aircrack-dkms-git-r1174.3a6402e-1 already made -- skipping build
 -> signal: killed
[sudo] password for argenisjimort:
loading packages...
warning: rtl88xxau-aircrack-dkms-git-r1174.3a6402e-1 is up to date -- reinstalling
resolving dependencies...
Package (1)                  Old Version      New Version      Net Change
rtl88xxau-aircrack-dkms-git  r1174.3a6402e-1  r1174.3a6402e-1    0,00 MiB
Total Installed Size:  50,87 MiB
Net Upgrade Size:       0,00 MiB
:: Proceed with installation? [Y/n]
(1/1) checking keys in keyring                       [----------------------------] 100%
(1/1) checking package integrity                     [----------------------------] 100%
(1/1) loading package files                          [----------------------------] 100%
(1/1) checking for file conflicts                    [----------------------------] 100%
:: Running pre-transaction hooks...
(1/1) Remove upgraded DKMS modules
:: Processing package changes...
(1/1) reinstalling rtl88xxau-aircrack-dkms-git       [----------------------------] 100%
So it seems there is some reason why it’s not working. :thinking: It’s very strange to me as i have a lot of Tp-link WiFi cards but they are internal Pci-E cards and they use Broadcom chips.
I ask again:
Do you have kernel headers installed? Do they match the kernel version?
sorry for not answering earlier. here is the output
$ pacman -Q | grep linux
archlinux-appstream-data 20211210-1
archlinux-keyring 20211028-1
lib32-util-linux 2.37.2-1
linux 5.15.10.arch1-1
linux-api-headers 5.12.3-1
linux-atm 2.5.2-7
linux-firmware 20211027.1d00989-1
linux-headers 5.15.11.arch2-1
linux-lts 5.10.88-2
util-linux 2.37.2-4
util-linux-libs 2.37.2-4
Your kernel is 5.15.10, and your headers are 5.15.11.
I don’t know what you’ve been doing to achieve that partial upgrade state, but UPDATE YOUR SYSTEM, reboot, and try building the package again; when yay asks you to for “packages to cleanbuild,” type A (for “All”) just in case.
EDIT - I missed that you also have the LTS kernel - you’ll probably want to install the linux-lts-headers package.
He might have done it manually. I think it would be better if he can use akm.
There may be some active IgnorePkg setting in his /etc/pacman.conf.
