I seen that in config #mangobar -c ~/.config/mango/mangobar/config.jsonc -s ~/.config/mango/mangobar/style.css 2>&1 &
is inocrrect because this options not is mangobars so I commented it and manually copied configs.
Again only wallpaper with cat.What should I do?
❯ mango
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Multiple symbols for level 1/group 1 on key <FK23>
> Using F23, ignoring XF86TouchpadOff
> Warning: Symbol map for key <FK23> redefined
> Using last definition for conflicting fields
> Warning: Symbol map for key <FK24> redefined
Errors from xkbcomp are not fatal to the X server
> Warning: Unsupported maximum keycode 709, clipping.
> X11 cannot support keycodes above 255.
> Warning: Virtual modifier Hyper multiply defined
> Using 0, ignoring 0
> Warning: Virtual modifier ScrollLock multiply defined
> Using 0, ignoring 0
> Using 0, ignoring 0
> Using 0, ignoring 0
Have you confirmed these packages are in your distro’s repositories?
AFAIC Fedora or any DNF-based distro would not ship a git package in its repo, so I guess you would have to compile them manually.
❯ LC_ALL=C sudo dnf install rofi foot xdg-desktop-portal-wlr swaybg mangobar-git wl-clip-persist cliphist wl-clipboard wlsunset xfce-polkit swaync pamixer swayidle dimland-git brightnessctl swayosd wlr-randr grim slurp satty swaylock-effects-git wlogout sox gpu-screen-recorder --skip-unavailable
Updating and loading repositories:
Repositories loaded.
Package "rofi-2.0.0-2.fc44.x86_64" is already installed.
Package "foot-1.27.0-1.fc44.x86_64" is already installed.
Package "xdg-desktop-portal-wlr-0.8.4-1.fc44.x86_64" is already installed.
Package "swaybg-1.2.2-1.fc44.x86_64" is already installed.
No match for argument: mangobar-git
No match for argument: wl-clip-persist
Package "cliphist-0.7.0-1.fc44.x86_64" is already installed.
Package "wl-clipboard-2.2.1^git20251124.e808203-2.fc44.x86_64" is already installed.
Package "wlsunset-0.4.0-4.fc43.x86_64" is already installed.
Package "xfce-polkit-0.3-17.fc44.x86_64" is already installed.
Package "SwayNotificationCenter-0.12.6-1.fc44.x86_64" is already installed.
Package "pamixer-1.6-7.fc44.x86_64" is already installed.
Package "swayidle-1.9.0-2.fc44.x86_64" is already installed.
No match for argument: dimland-git
Package "brightnessctl-0.5.1-16.fc44.x86_64" is already installed.
Package "SwayOSD-0.3.2-1.fc44.x86_64" is already installed.
Package "wlr-randr-0.5.0-3.fc44.x86_64" is already installed.
Package "grim-1.5.0-3.fc44.x86_64" is already installed.
Package "slurp-1.5.0-6.fc44.x86_64" is already installed.
Package "satty-0.22.0-1.fc44.x86_64" is already installed.
No match for argument: swaylock-effects-git
Package "wlogout-1.2.2-5.fc44.x86_64" is already installed.
Package "sox-14.4.2.0-44.fc44.x86_64" is already installed.
Package "gpu-screen-recorder-6.1.7-1.fc44.x86_64" is already installed.
Nothing to do.
I even compiled dimland . But mango still does not work, log:
> Using 0, ignoring 0
> Using 0, ignoring 0
> Using 0, ignoring 0
> Using 0, ignoring 0
It is not for the main question because I installed all (still mango have issue with setup),but I have it:
❯ LC_ALL=C sudo dnf install --nogpgcheck --repofrompath 'terra,``https://repos.fyralabs.com/terra$releasever``' terra-release
Failed to create repo "terra": Id is present more than once in the configuration
