Hi all,
Running into a strange issue on i3wm. I have been running endeavourOS with i3 for a couple of years now and have set my screen timeout through the xpce4-power-manager gui app. However, after the last update, my system goes into a screen timeout after 10 minutes, even though my settings have it set for 60 minutes. Even when I check xset, it also has the same setting:
xset q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 660 repeat rate: 25
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 600 cycle: 600
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
built-ins
DPMS (Display Power Management Signaling):
Standby: 3600 Suspend: 0 Off: 0
DPMS is Enabled
Monitor is On
I do not set this elsewhere either. There is no setting in my i3 config, there is no setting in my xinitrc, and there is no file at /etc/X11/xorg.conf.d/10-serverflags.conf (as recommended by the following https://wiki.archlinux.org/title/Display_Power_Management_Signaling)
So I am not sure why it is that the screen is timing out after 10 minutes. Any ideas would be most helpful!
