Dolphin won't load after updating KDE Framework to 6.29
After updating to the new KDE framework 6.29 today, Dolphin refuses to start. When launching it from the CLI, I get the following error: dolphin: error while loading shared libraries: liblmdb.so.1: cannot open shared object file: No such file or directory.
Yeah discovered the same thing this am. Just switched to Krusader until dolphin is fixed.
Same problem here. Tried uninstalling dolphin-plugins and dolphin, then re-installed, still not working, so using krusader for now
Seems to have been a problem with baloo (again) because I just received a baloo update that fixed dolphin.
That didn’t take long!
After the update today morning, I get the following error on loading dolphin:
Same here. After the framework update Dolphin wont load and I get the same error (dolphin: error while loading shared libraries: liblmdb.so.1: cannot open shared object file: No such file or directory
) Anyway, it seems better to begin a new thread, I am not sure it’s related to the NFS network…
Sounds as patrial update. May worth a try to update mirrors and check for new updates.
There was an update to Baloo which fixed this. Run an update.
I made another update and then baloo was updated.
Now, it works.
I didn’t run into this problem. I probably updated at a different time interval when it was already fixed.
