I am facing a very weird problem when connecting external monitors to my laptop:
Connecting one monitor directly with hdmi works most of the time. But when I also connect my Docking Station with 2 more monitors attached (Displayport) I get kicked out of my gnome session to gdm.
When trying to log in again one of 3 things happen: I either get a gray screen and have to hard reset my system, I get logged in but just my internal laptop screen works or I get logged in an my laptop screen + hdmi monitor work and the 2 others arent even detected.
Which is weird because the very first time I tried this configuration, it worked flawlessly out of the box. The Docking Station worked fine in Linux the first time I tried and still works under Windows, also other devices connected to it work.
My System:
EOS, fresh install, Gnome 46 using Wayland Session (Tested X11 too, same problem)
Asus ROG Strinx Scar 17 (2023)
AMD Ryzen 9 7945HX3D with iGPU and Nvidia RTX 4090 with Advanced Optimus
Proprietary Drivers installed, envycontrol set to hybrid mode
The output of inxi -Faz
Kernel: 6.8.9-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=48ab2981-8588-4b72-bc15-06a29d9414c1 rw rootflags=subvol=@
nowatchdog nvme_load=YES
rd.luks.uuid=59b154d3-3abf-4055-b636-0421662ff43f loglevel=3
nvidia-drm.modeset=1
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G733PYV_G733PYV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G733PYV v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G733PYV.329
date: 01/22/2024
Battery:
ID-1: BAT0 charge: 89.4 Wh (100.0%) condition: 89.4/90.0 Wh (99.3%)
volts: 17.3 min: 15.9 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: AMD Ryzen 9 7945HX3D with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 1253 high: 3602 min/max: 400/5455 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 3590 5: 400 6: 3120 7: 400 8: 400 9: 3602 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 3526 19: 3366 20: 3577 21: 400
22: 400 23: 400 24: 400 25: 3593 26: 400 27: 3481 28: 400 29: 400 30: 3042
31: 400 32: 400 bogomips: 146992
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow mitigation: Safe RET
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA GN21-X11 vendor: ASUSTeK driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-3,DP-4,HDMI-A-1 empty: DP-1,DP-2,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:2757 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-5, DP-6,
DP-7, Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 52.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5458
class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: gpu: amdgpu,nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: DP-3 model: Samsung LU28R55 serial: <filter> built: 2021
res: 3840x2160 dpi: 154 gamma: 1.2 size: 632x360mm (24.88x14.17")
diag: 727mm (28.6") ratio: 16:9 modes: N/A
Monitor-2: DP-4 model: Samsung LU28R55 serial: <filter> built: 2038
Monitor-3: HDMI-A-1 model: MSI MAG274QRF-QD serial: <filter> built: 2021
res: 2560x1440 dpi: 109 gamma: 1.2 size: 596x335mm (23.46x13.19")
diag: 684mm (26.9") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-4: eDP-2 model: BOE Display NE173QHM-NZ2 built: 2022
res: 2560x1440 dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43")
diag: 437mm (17.2") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
raphael_mendocino LLVM 17.0.6 DRM 3.57 6.8.9-arch1-2) device-ID: 1002:164e
memory: 500 MiB unified: no display-ID: :0.0
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:22bb class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Elgato Systems GmbH Wave:3 driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1.3.3:8
chip-ID: 0fd9:0070 class-ID: fe01 serial: <filter>
API: ALSA v: k6.8.9-arch1-2 status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8125 class-ID: 0200
IF: enp3s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4.4:6
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp7s0u1u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0489:e0f6
class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no
Local Storage: total: 5.55 TiB used: 67.57 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 731030WD temp: 26.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 67.57 GiB (3.6%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-59b154d3-3abf-4055-b636-0421662ff43f
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 728 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 67.57 GiB (3.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
System Temperatures: cpu: 54.0 C mobo: 30.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.56 GiB used: 3.37 GiB (11.0%)
Processes: 508 Power: uptime: 31m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 12.18 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1149 pm: pacman pkgs: 1129 libs: 309 tools: gnome-software,yay
pm: flatpak pkgs: 20 Compilers: gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.34
EDIT: I probably messed up something else when trying X11. I have done the test again and all monitors work under X11. But I would still prefer to use Wayland since the monitors all have different resolutions and sizes which does not work too well under X11.
Here is the journalctl from launching a Wayland session:
Mai 10 12:09:05 endeavour dbus-broker-launch[8375]: Ready
Mai 10 12:09:05 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=8380 comm="/usr/lib/gnome-session-binar>
Mai 10 12:09:05 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mai 10 12:09:05 endeavour gnome-session[8380]: gnome-session-binary[8380]: WARNING: Could not check if unit gnome-session-wayland@gnome-login.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process >
Mai 10 12:09:05 endeavour gnome-session-binary[8380]: WARNING: Could not check if unit gnome-session-wayland@gnome-login.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.syste>
Mai 10 12:09:05 endeavour gnome-session[8380]: gnome-session-binary[8380]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a mis>
Mai 10 12:09:05 endeavour gnome-session-binary[8380]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
Mai 10 12:09:05 endeavour gnome-shell[8392]: Running GNOME Shell (using mutter 46.1) as a Wayland display server
Mai 10 12:09:05 endeavour rtkit-daemon[1358]: Supervising 5 threads of 3 processes of 1 users.
Mai 10 12:09:05 endeavour rtkit-daemon[1358]: Successfully made thread 8410 of process 8392 owned by '120' RT at priority 20.
Mai 10 12:09:05 endeavour rtkit-daemon[1358]: Supervising 6 threads of 4 processes of 2 users.
Mai 10 12:09:05 endeavour gnome-shell[8392]: Made thread 'KMS thread' realtime scheduled
Mai 10 12:09:05 endeavour gnome-shell[8392]: Device '/dev/dri/card0' prefers shadow buffer
Mai 10 12:09:05 endeavour gnome-shell[8392]: Added device '/dev/dri/card0' (nvidia-drm) using atomic mode setting.
Mai 10 12:09:05 endeavour gnome-shell[8392]: Device '/dev/dri/card1' prefers shadow buffer
Mai 10 12:09:05 endeavour gnome-shell[8392]: Added device '/dev/dri/card1' (amdgpu) using atomic mode setting.
Mai 10 12:09:05 endeavour gnome-shell[8392]: Created gbm renderer for '/dev/dri/card0'
Mai 10 12:09:05 endeavour gnome-shell[8392]: Created gbm renderer for '/dev/dri/card1'
Mai 10 12:09:05 endeavour gnome-shell[8392]: Boot VGA GPU /dev/dri/card1 selected as primary
Mai 10 12:09:05 endeavour gnome-shell[8392]: Obtained a high priority EGL context
Mai 10 12:09:06 endeavour gnome-shell[8392]: Failed to read monitors config file '/var/lib/gdm/.config/monitors.xml': A fractional scale with physical layout mode not allowed
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=8392 comm="/usr/bin/gnome-shell")
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Successfully activated service 'org.a11y.Bus'
Mai 10 12:09:06 endeavour gnome-shell[8392]: Using public X11 display :1024, (using :1025 for managed services)
Mai 10 12:09:06 endeavour gnome-shell[8392]: Using Wayland display name 'wayland-0'
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8446]: dbus-daemon[8446]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=8392 comm="/usr/bin/gnome-shell")
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8446]: dbus-daemon[8446]: Successfully activated service 'org.a11y.atspi.Registry'
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8450]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Mai 10 12:09:06 endeavour gnome-shell[8392]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Mai 10 12:09:06 endeavour gnome-shell[8392]: Will monitor session 8
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=8392 comm="/usr/bin/gnome-shell")
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=8392 comm="/usr/bin/>
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=8392 comm="/usr/bin/gnome-shell")
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8392]: Window manager warning: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10947fdb78f9b3e9bd171533574513309900000083800000.ms”: No>
Mai 10 12:09:06 endeavour gnome-shell[8392]: Failed to launch ibus-daemon: Failed to execute child process “ibus-daemon” (No such file or directory)
Mai 10 12:09:06 endeavour gnome-shell[8392]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Mai 10 12:09:06 endeavour systemd[1]: Starting Locale Service...
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Successfully activated service 'org.gnome.Shell.Notifications'
Mai 10 12:09:06 endeavour systemd[1]: Starting Hostname Service...
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.freedesktop.systemd1' requested by ':1.23' (uid=120 pid=8535 comm="/usr/lib/gsd-sharing")
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mai 10 12:09:06 endeavour gsd-sharing[8535]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mai 10 12:09:06 endeavour polkitd[1234]: Registered Authentication Agent for unix-session:8 (system bus name :1.186 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Mai 10 12:09:06 endeavour systemd[1]: Started Locale Service.
Mai 10 12:09:06 endeavour NetworkManager[1203]: <info> [1715335746.3113] agent-manager: agent[e450316297c42091,:1.186/org.gnome.Shell.NetworkAgent/120]: agent registered
Mai 10 12:09:06 endeavour systemd[1]: Started Hostname Service.
Mai 10 12:09:06 endeavour systemd[8360]: Started PipeWire Multimedia Service.
Mai 10 12:09:06 endeavour systemd[8360]: Started Multimedia Service Session Manager.
Mai 10 12:09:06 endeavour systemd[8360]: Started PipeWire PulseAudio.
Mai 10 12:09:06 endeavour systemd[1]: Starting Location Lookup Service...
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 6 threads of 4 processes of 2 users.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8651 of process 8651 owned by '120' high priority at nice level -11.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 7 threads of 5 processes of 2 users.
Mai 10 12:09:06 endeavour kernel: rfkill: input handler disabled
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8674 of process 8651 owned by '120' RT at priority 20.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 8 threads of 5 processes of 2 users.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8653 of process 8653 owned by '120' high priority at nice level -11.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 9 threads of 6 processes of 2 users.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8659 of process 8659 owned by '120' high priority at nice level -11.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 10 threads of 7 processes of 2 users.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8681 of process 8659 owned by '120' RT at priority 20.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 11 threads of 7 processes of 2 users.
Mai 10 12:09:06 endeavour systemd[1]: Started Location Lookup Service.
Mai 10 12:09:06 endeavour gnome-shell[8392]: g_variant_new_string: assertion 'string != NULL' failed
Mai 10 12:09:06 endeavour colord[1413]: CdMain: failed to profile from filename: failed to load file: Error opening file /[Invalid UTF-8]: No such file or directory
Mai 10 12:09:06 endeavour gnome-shell[8392]: Failed to create colord color profile icc-01273c7f5b4069eb3efdfba1faf9fff6: failed to load file: Error opening file /[Invalid UTF-8]: No such file or directory
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Successfully activated service 'org.gnome.Shell.Screencast'
Mai 10 12:09:06 endeavour gnome-session-binary[8380]: Entering running state
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8410 of process 8392 owned by '120' high priority at nice level 0.
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/ldac
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aptx_hd
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_hd
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aac
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aac
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc_xq
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc_xq
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream_duplex
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Mai 10 12:09:06 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Mai 10 12:09:06 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_chrc() Failed to create characteristic entry in database
Mai 10 12:09:06 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_service() Failed to add characteristic
Mai 10 12:09:06 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_app() Failed to add service
Mai 10 12:09:06 endeavour bluetoothd[1206]: src/gatt-database.c:client_ready_cb() Failed to create GATT service entry in local database
Mai 10 12:09:06 endeavour wireplumber[8653]: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.Failed: Failed to create entry in database
Mai 10 12:09:06 endeavour wireplumber[8653]: [0:39:22.034887876] [8653] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Mai 10 12:09:06 endeavour wireplumber[8653]: [0:39:22.034898285] [8653] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Mai 10 12:09:06 endeavour wireplumber[8653]: [0:39:22.034916389] [8653] INFO Camera camera_manager.cpp:284 libcamera v0.2.0
Mai 10 12:09:06 endeavour gsd-media-keys[8499]: Unable to get default sink
Mai 10 12:09:06 endeavour gsd-media-keys[8499]: Unable to get default source
Mai 10 12:09:06 endeavour systemd[8360]: Starting sandboxed app permission store...
Mai 10 12:09:06 endeavour systemd[8360]: Started sandboxed app permission store.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Supervising 10 threads of 6 processes of 2 users.
Mai 10 12:09:06 endeavour rtkit-daemon[1358]: Successfully made thread 8410 of process 8392 owned by '120' RT at priority 20.
Mai 10 12:09:06 endeavour gsd-media-keys[8499]: Failed to grab accelerator for keybinding settings:playback-repeat
Mai 10 12:09:06 endeavour gsd-media-keys[8499]: Failed to grab accelerator for keybinding settings:hibernate
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Activating service name='org.gnome.ScreenSaver' requested by ':1.16' (uid=120 pid=8494 comm="/usr/lib/gsd-power")
Mai 10 12:09:06 endeavour gnome-shell[8392]: Registering session with GDM
Mai 10 12:09:06 endeavour /usr/lib/gdm-wayland-session[8379]: dbus-daemon[8379]: [session uid=120 pid=8379] Successfully activated service 'org.gnome.ScreenSaver'
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: > Warning: Unsupported maximum keycode 708, clipping.
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: > X11 cannot support keycodes above 255.
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: > Warning: Could not resolve keysym XF86KbdInputAssistPrevgrou
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: > Warning: Could not resolve keysym XF86KbdInputAssistNextgrou
Mai 10 12:09:06 endeavour org.gnome.Shell.desktop[8752]: Errors from xkbcomp are not fatal to the X server
Mai 10 12:09:12 endeavour gdm-password][8773]: gkr-pam: unable to locate daemon control file
Mai 10 12:09:12 endeavour gdm-password][8773]: gkr-pam: stashed password to try later in open session
Mai 10 12:09:12 endeavour gdm-password][8773]: pam_unix(gdm-password:session): session opened for user marlon(uid=1000) by marlon(uid=0)
Mai 10 12:09:12 endeavour systemd-logind[1216]: New session 10 of user marlon.
Mai 10 12:09:12 endeavour systemd[1]: Started Session 10 of User marlon.
Mai 10 12:09:12 endeavour systemd[1809]: Started GNOME Keyring daemon.
Mai 10 12:09:12 endeavour gnome-keyring-daemon[8786]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Mai 10 12:09:12 endeavour gdm-password][8773]: gkr-pam: unlocked login keyring
Mai 10 12:09:13 endeavour wireplumber[8653]: [string "alsa.lua"]:178: table index is nil
stack traceback:
[string "alsa.lua"]:178: in function <[string "alsa.lua"]:172>
Mai 10 12:09:13 endeavour kernel: rfkill: input handler enabled
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/ldac
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aptx_hd
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_hd
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aac
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aac
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc
Mai 10 12:09:13 endeavour gsd-media-keys[8499]: Unable to get default source
Mai 10 12:09:13 endeavour gsd-media-keys[8499]: Unable to get default sink
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc_xq
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc_xq
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream_duplex
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Mai 10 12:09:13 endeavour bluetoothd[1206]: Endpoint unregistered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Mai 10 12:09:13 endeavour systemd[1809]: Reached target GNOME Wayland Session.
Mai 10 12:09:13 endeavour systemd[1809]: Reached target Session services which should run early before the graphical session is brought up.
Mai 10 12:09:13 endeavour systemd[1809]: Reached target GNOME Shell.
Mai 10 12:09:13 endeavour systemd[1809]: Starting Monitor Session leader for GNOME Session...
Mai 10 12:09:13 endeavour systemd[1809]: Started Monitor Session leader for GNOME Session.
Mai 10 12:09:13 endeavour systemd[1809]: Reached target Tasks to be run before GNOME Session starts.
Mai 10 12:09:13 endeavour systemd[1809]: Starting GNOME Session Manager (session: gnome)...
Mai 10 12:09:13 endeavour gnome-keyring-daemon[8786]: The PKCS#11 component was already initialized
Mai 10 12:09:13 endeavour gnome-keyring-d[8786]: The PKCS#11 component was already initialized
Mai 10 12:09:13 endeavour gnome-keyring-daemon[8877]: discover_other_daemon: 1
Mai 10 12:09:13 endeavour gnome-keyring-pkcs11.desktop[8877]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Mai 10 12:09:13 endeavour gnome-keyring-daemon[8786]: The Secret Service was already initialized
Mai 10 12:09:13 endeavour gnome-keyring-d[8786]: The Secret Service was already initialized
Mai 10 12:09:13 endeavour gnome-keyring-daemon[8883]: discover_other_daemon: 1
Mai 10 12:09:13 endeavour gnome-keyring-secrets.desktop[8883]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dpkcs11-8868.scope: PID 8868 vanished before we could move it to target cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-gnome\x2dkeyrin>
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dpkcs11-8868.scope: No PIDs left to attach to the scope's control group, refusing.
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dpkcs11-8868.scope: Failed with result 'resources'.
Mai 10 12:09:13 endeavour systemd[1809]: Failed to start Application launched by gnome-session-binary.
Mai 10 12:09:13 endeavour gnome-keyring-daemon[8886]: discover_other_daemon: 1
Mai 10 12:09:13 endeavour gnome-keyring-ssh.desktop[8886]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dsecrets-8870.scope: PID 8870 vanished before we could move it to target cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-gnome\x2dkeyri>
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dsecrets-8870.scope: No PIDs left to attach to the scope's control group, refusing.
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dsecrets-8870.scope: Failed with result 'resources'.
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dssh-8875.scope: PID 8875 vanished before we could move it to target cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-gnome\x2dkeyring\x>
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dssh-8875.scope: No PIDs left to attach to the scope's control group, refusing.
Mai 10 12:09:13 endeavour systemd[1809]: app-gnome-gnome\x2dkeyring\x2dssh-8875.scope: Failed with result 'resources'.
Mai 10 12:09:13 endeavour systemd[1809]: Started GNOME Session Manager (session: gnome).
Mai 10 12:09:13 endeavour systemd[1809]: Reached target GNOME Session Manager is ready.
Mai 10 12:09:13 endeavour systemd[1809]: Starting GNOME Shell on Wayland...
Mai 10 12:09:13 endeavour systemd[1809]: GNOME Shell on X11 was skipped because of an unmet condition check (ConditionEnvironment=XDG_SESSION_TYPE=x11).
Mai 10 12:09:13 endeavour systemd[1809]: Starting Virtual filesystem service...
Mai 10 12:09:13 endeavour systemd[1809]: Started Virtual filesystem service.
Mai 10 12:09:13 endeavour gnome-shell[8888]: Running GNOME Shell (using mutter 46.1) as a Wayland display server
Mai 10 12:09:13 endeavour gnome-shell[8888]: Enabling experimental feature 'scale-monitor-framebuffer'
Mai 10 12:09:13 endeavour rtkit-daemon[1358]: Supervising 11 threads of 7 processes of 2 users.
Mai 10 12:09:13 endeavour rtkit-daemon[1358]: Successfully made thread 8921 of process 8888 owned by '1000' RT at priority 20.
Mai 10 12:09:13 endeavour rtkit-daemon[1358]: Supervising 12 threads of 8 processes of 2 users.
Mai 10 12:09:13 endeavour gnome-shell[8888]: Made thread 'KMS thread' realtime scheduled
Mai 10 12:09:13 endeavour gnome-shell[8888]: Device '/dev/dri/card0' prefers shadow buffer
Mai 10 12:09:14 endeavour gnome-shell[8888]: Added device '/dev/dri/card0' (nvidia-drm) using atomic mode setting.
Mai 10 12:09:14 endeavour gnome-shell[8888]: Failed to create KMS output: No modes available
Mai 10 12:09:14 endeavour gnome-shell[8888]: Device '/dev/dri/card1' prefers shadow buffer
Mai 10 12:09:14 endeavour gnome-shell[8888]: Added device '/dev/dri/card1' (amdgpu) using atomic mode setting.
Mai 10 12:09:14 endeavour gnome-shell[8888]: Created gbm renderer for '/dev/dri/card0'
Mai 10 12:09:14 endeavour gnome-shell[8888]: Created gbm renderer for '/dev/dri/card1'
Mai 10 12:09:14 endeavour gnome-shell[8888]: Boot VGA GPU /dev/dri/card1 selected as primary
Mai 10 12:09:14 endeavour gnome-shell[8888]: Obtained a high priority EGL context
Mai 10 12:09:14 endeavour wireplumber[2501]: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
Mai 10 12:09:14 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_chrc() Failed to create characteristic entry in database
Mai 10 12:09:14 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_service() Failed to add characteristic
Mai 10 12:09:14 endeavour bluetoothd[1206]: src/gatt-database.c:database_add_app() Failed to add service
Mai 10 12:09:14 endeavour bluetoothd[1206]: src/gatt-database.c:client_ready_cb() Failed to create GATT service entry in local database
Mai 10 12:09:14 endeavour wireplumber[2501]: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.Failed: Failed to create entry in database
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/ldac
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/aptx_hd
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aptx_hd
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/aac
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aac
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/sbc
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/sbc
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/sbc_xq
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/sbc_xq
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/faststream
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/faststream_duplex
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/opus_05
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/opus_05
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Mai 10 12:09:14 endeavour bluetoothd[1206]: Endpoint registered: sender=:1.214 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Mai 10 12:09:14 endeavour systemd[1809]: Starting sandboxed app permission store...
Mai 10 12:09:14 endeavour systemd[1809]: Started sandboxed app permission store.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Accessibility services bus...
Mai 10 12:09:14 endeavour systemd[1809]: Started Accessibility services bus.
Mai 10 12:09:14 endeavour at-spi-bus-launcher[9038]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
Mai 10 12:09:14 endeavour at-spi-bus-launcher[9038]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
Mai 10 12:09:14 endeavour dbus-broker-launch[9038]: Ready
Mai 10 12:09:14 endeavour gnome-shell[8888]: Using public X11 display :0, (using :1 for managed services)
Mai 10 12:09:14 endeavour gnome-shell[8888]: Using Wayland display name 'wayland-0'
Mai 10 12:09:14 endeavour systemd[1809]: Created slice Slice /app/dbus-:1.19-org.a11y.atspi.Registry.
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.19-org.a11y.atspi.Registry@0.service.
Mai 10 12:09:14 endeavour at-spi2-registryd[9041]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Mai 10 12:09:14 endeavour gnome-shell[8888]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Mai 10 12:09:14 endeavour gnome-shell[8888]: Will monitor session 10
Mai 10 12:09:14 endeavour gnome-shell[8888]: Could not issue 'GetUnit' systemd call
Mai 10 12:09:14 endeavour gnome-shell[8888]: Failed to launch ibus-daemon: Failed to execute child process “ibus-daemon” (No such file or directory)
Mai 10 12:09:14 endeavour gnome-shell[8888]: Gio.UnixInputStream has been moved to a separate platform-specific library. Please update your code to use GioUnix.InputStream instead.
0 inhibit() ["resource:///org/gnome/shell/misc/loginManager.js":209:8]
1 InterpretGeneratorResume() ["self-hosted":1455:33]
2 AsyncFunctionNext() ["self-hosted":852:26]
3 anonymous() ["resource:///org/gnome/shell/ui/init.js":21:19]
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.Shell.Screencast@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME Shell on Wayland.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME Session is initialized.
Mai 10 12:09:14 endeavour systemd[1809]: GNOME session X11 services is inactive.
Mai 10 12:09:14 endeavour systemd[1809]: Dependency failed for GNOME XSettings service.
Mai 10 12:09:14 endeavour systemd[1809]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
Mai 10 12:09:14 endeavour systemd[1809]: gnome-session-x11-services-ready.target: Job gnome-session-x11-services-ready.target/verify-active failed with result 'dependency'.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME Session (session: gnome).
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME XSettings target.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Signal initialization done to GNOME Session Manager...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME accessibility service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME color management service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME date & time service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME maintenance of expirable data service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME keyboard configuration service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME keyboard shortcuts service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME power management service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME printer notifications service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME RFKill support service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME FreeDesktop screensaver service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME file sharing service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME smartcard service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME sound sample caching service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME USB protection service...
Mai 10 12:09:14 endeavour systemd[1809]: Starting GNOME Wacom tablet support service...
Mai 10 12:09:14 endeavour systemd[1809]: Finished Signal initialization done to GNOME Session Manager.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME accessibility service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME maintenance of expirable data service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME FreeDesktop screensaver service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME date & time service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME RFKill support service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME smartcard service.
Mai 10 12:09:14 endeavour systemd[1809]: Started Application launched by gnome-session-binary.
Mai 10 12:09:14 endeavour kernel: rfkill: input handler disabled
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME accessibility target.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME date & time target.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME maintenance of expirable data target.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME RFKill support target.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME FreeDesktop screensaver target.
ai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME smartcard target.
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.Shell.CalendarServer@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.Shell.Notifications@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME file sharing service.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME USB protection service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME file sharing target.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME USB protection target.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME sound sample caching service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME sound sample caching target.
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.ScreenSaver@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Evolution source registry...
Mai 10 12:09:14 endeavour gnome-session-binary[8861]: Entering running state
Mai 10 12:09:14 endeavour systemd[1809]: app-gnome-wallpaper\x2donce-9229.scope: PID 9229 vanished before we could move it to target cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-wallpaper\x2donce-9229.s>
Mai 10 12:09:14 endeavour systemd[1809]: app-gnome-wallpaper\x2donce-9229.scope: No PIDs left to attach to the scope's control group, refusing.
Mai 10 12:09:14 endeavour systemd[1809]: app-gnome-wallpaper\x2donce-9229.scope: Failed with result 'resources'.
Mai 10 12:09:14 endeavour systemd[1809]: Failed to start Application launched by gnome-session-binary.
Mai 10 12:09:14 endeavour gnome-shell[8888]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Mai 10 12:09:14 endeavour gsd-usb-protect[9096]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.OnlineAccounts@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Virtual filesystem service - disk device monitor...
Mai 10 12:09:14 endeavour systemd[1809]: Started Evolution source registry.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Evolution calendar service...
Mai 10 12:09:14 endeavour systemd[1809]: Started Virtual filesystem service - disk device monitor.
Mai 10 12:09:14 endeavour goa-daemon[9331]: goa-daemon version 3.50.1 starting
Mai 10 12:09:14 endeavour systemd[1809]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Mai 10 12:09:14 endeavour systemd[1809]: Started dbus-:1.2-org.gnome.Identity@0.service.
Mai 10 12:09:14 endeavour systemd[1809]: Started Evolution calendar service.
Mai 10 12:09:14 endeavour systemd[1809]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Virtual filesystem service - digital camera monitor...
Mai 10 12:09:14 endeavour systemd[1809]: Starting Evolution address book service...
Mai 10 12:09:14 endeavour systemd[1809]: Started Virtual filesystem service - digital camera monitor.
Mai 10 12:09:14 endeavour systemd[1809]: Starting Virtual filesystem service - Apple File Conduit monitor...
Mai 10 12:09:14 endeavour systemd[1809]: Started Virtual filesystem service - Apple File Conduit monitor.
Mai 10 12:09:14 endeavour systemd[1809]: Started Evolution address book service.
Mai 10 12:09:14 endeavour polkitd[1234]: Registered Authentication Agent for unix-session:10 (system bus name :1.217 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Mai 10 12:09:14 endeavour gnome-shell[8888]: g_variant_new_string: assertion 'string != NULL' failed
Mai 10 12:09:14 endeavour colord[1413]: CdMain: failed to profile from filename: failed to load file: Error opening file /[Invalid UTF-8]: No such file or directory
Mai 10 12:09:14 endeavour gnome-shell[8888]: Failed to create colord color profile icc-a7ce7c36779d88f9f375ea2a34f4e9f6: failed to load file: Error opening file /[Invalid UTF-8]: No such file or directory
Mai 10 12:09:14 endeavour NetworkManager[1203]: <info> [1715335754.8967] agent-manager: agent[6e984c815e73e665,:1.217/org.gnome.Shell.NetworkAgent/1000]: agent registered
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME keyboard configuration service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME keyboard configuration target.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME color management service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME color management target.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME keyboard shortcuts service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME keyboard shortcuts target.
Mai 10 12:09:14 endeavour systemd[1809]: Started GNOME power management service.
Mai 10 12:09:14 endeavour systemd[1809]: Reached target GNOME power management target.
Mai 10 12:09:14 endeavour gsd-media-keys[9063]: Failed to grab accelerator for keybinding settings:hibernate
Mai 10 12:09:15 endeavour systemd[1809]: Starting Portal service...
Mai 10 12:09:15 endeavour systemd[1809]: Started GNOME Wacom tablet support service.
Mai 10 12:09:15 endeavour systemd[1809]: Reached target GNOME Wacom tablet support target.
Mai 10 12:09:15 endeavour systemd[1809]: Starting flatpak document portal service...
Mai 10 12:09:15 endeavour rtkit-daemon[1358]: Successfully made thread 8921 of process 8888 owned by '1000' high priority at nice level 0.
Mai 10 12:09:15 endeavour rtkit-daemon[1358]: Supervising 12 threads of 8 processes of 2 users.
Mai 10 12:09:15 endeavour systemd[1809]: Started flatpak document portal service.
Mai 10 12:09:15 endeavour rtkit-daemon[1358]: Supervising 11 threads of 7 processes of 2 users.
Mai 10 12:09:15 endeavour rtkit-daemon[1358]: Successfully made thread 8921 of process 8888 owned by '1000' RT at priority 20.
Mai 10 12:09:15 endeavour systemd[1809]: Started GNOME printer notifications service.
Mai 10 12:09:15 endeavour systemd[1809]: Reached target GNOME printer notifications target.
Mai 10 12:09:15 endeavour systemd[1809]: Reached target GNOME Session.
Mai 10 12:09:15 endeavour systemd[1809]: Reached target GNOME Wayland Session (session: gnome).
Mai 10 12:09:15 endeavour systemd[1809]: Reached target Current graphical user session.
Mai 10 12:09:15 endeavour systemd[1809]: Starting Portal service (GNOME implementation)...
Mai 10 12:09:15 endeavour systemd[1809]: Started Portal service (GNOME implementation).
Mai 10 12:09:15 endeavour welcome.desktop[9195]: Welcome app is disabled. To start it anyway, use option --enable (temporarily: --once).
Mai 10 12:09:15 endeavour systemd[1809]: Starting Portal service (GTK/GNOME implementation)...
Mai 10 12:09:15 endeavour gnome-shell[8888]: GNOME Shell started at Fri May 10 2024 12:09:14 GMT+0200 (Central European Summer Time)
Mai 10 12:09:15 endeavour gnome-shell[8888]: Registering session with GDM
Mai 10 12:09:15 endeavour gnome-shell[8392]: Connection to xwayland lost
Mai 10 12:09:15 endeavour gnome-shell[8392]: Xwayland terminated, exiting since it was mandatory
Mai 10 12:09:15 endeavour gnome-shell[8392]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
@resource:///org/gnome/shell/ui/init.js:21:20
Mai 10 12:09:15 endeavour gnome-shell[8392]: Execution of main.js threw exception: Module resource:///org/gnome/shell/ui/init.js threw an exception
Mai 10 12:09:15 endeavour systemd[1809]: Started Portal service (GTK/GNOME implementation).
Mai 10 12:09:15 endeavour systemd-logind[1216]: Session 8 logged out. Waiting for processes to exit.
Mai 10 12:09:15 endeavour systemd[1809]: Started Portal service.
Mai 10 12:09:15 endeavour polkitd[1234]: Unregistered Authentication Agent for unix-session:8 (system bus name :1.186, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Mai 10 12:09:15 endeavour systemd[1]: session-8.scope: Deactivated successfully.
Mai 10 12:09:15 endeavour systemd[1]: session-8.scope: Consumed 3.070s CPU time.
Mai 10 12:09:15 endeavour systemd-logind[1216]: Removed session 8.
Mai 10 12:09:15 endeavour gnome-software[9208]: Failed to load /usr/lib/gnome-software/plugins-20/libgs_plugin_fwupd.so: failed to open plugin /usr/lib/gnome-software/plugins-20/libgs_plugin_fwupd.so: libfwupd.so.2: cannot open sha>
Mai 10 12:09:15 endeavour gdm[1279]: Gdm: Child process -8371 was already dead.
Mai 10 12:09:17 endeavour gnome-software[9208]: Tried to set invalid release date: 2022
Mai 10 12:09:23 endeavour gnome-software[9208]: Failed to reload changed app filter: App filtering is globally disabled
Mai 10 12:09:24 endeavour gnome-software[9208]: Failed to reload changed app filter: App filtering is globally disabled
Mai 10 12:09:25 endeavour systemd[1]: Stopping User Manager for UID 120...
Mai 10 12:09:25 endeavour systemd[8360]: Activating special unit Exit the Session...
Mai 10 12:09:25 endeavour systemd[8360]: Stopped target Main User Target.
Mai 10 12:09:25 endeavour systemd[8360]: Stopping PipeWire PulseAudio...
Mai 10 12:09:25 endeavour systemd[8360]: Stopping sandboxed app permission store...
