Hi all. Been using endevour os for some time and I cannot get docker to work.
-- Boot 1bea486bffcf43dbab79da79d5b129fa --
Dec 31 07:15:16 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:15:17 Lok dockerd[5177]: time="2024-12-31T07:15:17.084142100Z" level=info msg="Starting up"
Dec 31 07:15:17 Lok dockerd[5177]: time="2024-12-31T07:15:17.112531441Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:15:18 Lok dockerd[5177]: time="2024-12-31T07:15:18.112795296Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:15:20 Lok dockerd[5177]: time="2024-12-31T07:15:20.113945113Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:15:24 Lok dockerd[5177]: time="2024-12-31T07:15:24.114496908Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:15:32 Lok dockerd[5177]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:15:32 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:15:32 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:15:32 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:15:32 Lok systemd[1]: docker.service: Consumed 101ms CPU time, 77.8M memory peak.
Dec 31 07:15:34 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Dec 31 07:15:34 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:15:34 Lok dockerd[8480]: time="2024-12-31T07:15:34.436518079Z" level=info msg="Starting up"
Dec 31 07:15:34 Lok dockerd[8480]: time="2024-12-31T07:15:34.451608113Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:15:35 Lok dockerd[8480]: time="2024-12-31T07:15:35.452127066Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:15:37 Lok dockerd[8480]: time="2024-12-31T07:15:37.453301900Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:15:41 Lok dockerd[8480]: time="2024-12-31T07:15:41.455456049Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:15:49 Lok dockerd[8480]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:15:49 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:15:49 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:15:49 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:15:51 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Dec 31 07:15:51 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:15:51 Lok dockerd[8800]: time="2024-12-31T07:15:51.675022092Z" level=info msg="Starting up"
Dec 31 07:15:51 Lok dockerd[8800]: time="2024-12-31T07:15:51.690703227Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:15:52 Lok dockerd[8800]: time="2024-12-31T07:15:52.691125898Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:15:54 Lok dockerd[8800]: time="2024-12-31T07:15:54.691413384Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:15:58 Lok dockerd[8800]: time="2024-12-31T07:15:58.694485013Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:16:06 Lok dockerd[8800]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:16:06 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:16:06 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:16:06 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:16:08 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Dec 31 07:16:08 Lok systemd[1]: docker.service: Start request repeated too quickly.
Dec 31 07:16:08 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:16:08 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:24:51 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:24:51 Lok dockerd[13540]: time="2024-12-31T07:24:51.374474832Z" level=info msg="Starting up"
Dec 31 07:24:51 Lok dockerd[13540]: time="2024-12-31T07:24:51.388393449Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:24:52 Lok dockerd[13540]: time="2024-12-31T07:24:52.388690622Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:24:54 Lok dockerd[13540]: time="2024-12-31T07:24:54.389891132Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:24:58 Lok dockerd[13540]: time="2024-12-31T07:24:58.393061689Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:25:06 Lok dockerd[13540]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:25:06 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:25:06 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:25:06 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:25:08 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Dec 31 07:25:08 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:25:08 Lok dockerd[13606]: time="2024-12-31T07:25:08.661757538Z" level=info msg="Starting up"
Dec 31 07:25:08 Lok dockerd[13606]: time="2024-12-31T07:25:08.675567228Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:25:09 Lok dockerd[13606]: time="2024-12-31T07:25:09.675892777Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:25:11 Lok dockerd[13606]: time="2024-12-31T07:25:11.677056367Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:25:15 Lok dockerd[13606]: time="2024-12-31T07:25:15.680217213Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:25:23 Lok dockerd[13606]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:25:23 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:25:23 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:25:23 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:25:25 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Dec 31 07:25:25 Lok systemd[1]: Starting Docker Application Container Engine...
Dec 31 07:25:25 Lok dockerd[13641]: time="2024-12-31T07:25:25.902262303Z" level=info msg="Starting up"
Dec 31 07:25:25 Lok dockerd[13641]: time="2024-12-31T07:25:25.921388661Z" level=warning msg="Unable to locate plugin: loki, retrying in 1s"
Dec 31 07:25:26 Lok dockerd[13641]: time="2024-12-31T07:25:26.921823915Z" level=warning msg="Unable to locate plugin: loki, retrying in 2s"
Dec 31 07:25:28 Lok dockerd[13641]: time="2024-12-31T07:25:28.922995980Z" level=warning msg="Unable to locate plugin: loki, retrying in 4s"
Dec 31 07:25:32 Lok dockerd[13641]: time="2024-12-31T07:25:32.926137434Z" level=warning msg="Unable to locate plugin: loki, retrying in 8s"
Dec 31 07:25:40 Lok dockerd[13641]: failed to start daemon: failed to set log opts: failed to set log opts: error looking up logging plugin loki: plugin "loki" not found
Dec 31 07:25:40 Lok systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 07:25:40 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:25:40 Lok systemd[1]: Failed to start Docker Application Container Engine.
Dec 31 07:25:43 Lok systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Dec 31 07:25:43 Lok systemd[1]: docker.service: Start request repeated too quickly.
Dec 31 07:25:43 Lok systemd[1]: docker.service: Failed with result 'exit-code'.
Dec 31 07:25:43 Lok systemd[1]: Failed to start Docker Application Container Engine.
Could it be because the br interface is missing?
5GiB/31GiB | 0B/34GiB on ☁️ (eu-west-2) with /usr/bin/zsh
🕙 07:32:17 zsh ❯ firewall-cmd --get-active-zones
block (default)
interfaces: enp5s0
docker
interfaces: docker0
libvirt
interfaces: virbr1 virbr4 virbr3 virbr0
Kernel Module seems to be installed
in /lib/modules/6.6.68-1-lts/kernel/net 5GiB/31GiB | 0B/34GiB on ☁️ (eu-west-2) with /usr/bin/zsh
🕙 07:35:24 zsh ❯ ls -l | grep "bridge"
drwxr-xr-x - root root 30 Dec 07:43 ├── bridge
in /lib/modules/6.6.68-1-lts/kernel/net 5GiB/31GiB | 0B/34GiB on ☁️ (eu-west-2) with /usr/bin/zsh took 47s
🕙 07:41:25 zsh ❯ sudo systemctl status docker
[sudo] password for:
× docker.service - Docker Application Container Engine
Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2024-12-31 07:25:43 GMT; 20min ago
Invocation: 3ac4a17eecab41c78551b1a4218eefc1
TriggeredBy: × docker.socket
Docs: https://docs.docker.com
Process: 13641 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/F>
Main PID: 13641 (code=exited, status=1/FAILURE)
