Here’s what happens when I try to change the sensitivity on xinput. It says device not found, but it only does that for code 346 which is the finger low and high
[gnome@gnome-notebook ~]$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SYNA3602:00 0911:5288 Mouse id=12 [slave pointer (2)]
⎜ ↳ SYNA3602:00 0911:5288 Touchpad id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Lid Switch id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ icspring camera: icspring camer id=11 [slave keyboard (3)]
↳ Intel HID events id=14 [slave keyboard (3)]
↳ Intel HID 5 button array id=15 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=16 [slave keyboard (3)]
[gnome@gnome-notebook ~]$ xinput --list-props 13
Device ‘SYNA3602:00 0911:5288 Touchpad’:
Device Enabled (185): 1
Coordinate Transformation Matrix (187): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (319): 1
Device Accel Constant Deceleration (320): 3.333333
Device Accel Adaptive Deceleration (321): 1.000000
Device Accel Velocity Scaling (322): 12.500000
Synaptics Edges (345): 52, 1258, 54, 946
Synaptics Finger (346): 25, 30, 0
Synaptics Tap Time (347): 140
Synaptics Tap Move (348): 72
Synaptics Tap Durations (349): 180, 180, 20
Synaptics ClickPad (350): 1
Synaptics Middle Button Timeout (351): 0
Synaptics Two-Finger Pressure (352): 282
Synaptics Two-Finger Width (353): 7
Synaptics Scrolling Distance (354): 32, 32
Synaptics Edge Scrolling (355): 0, 0, 0
Synaptics Two-Finger Scrolling (356): 1, 0
Synaptics Move Speed (357): 1.000000, 8.333333, 0.200000, 0.000000
Synaptics Off (358): 0
Synaptics Locked Drags (359): 0
Synaptics Locked Drags Timeout (360): 5000
Synaptics Tap Action (361): 0, 0, 0, 0, 1, 3, 2
Synaptics Click Action (362): 1, 3, 2
Synaptics Circular Scrolling (363): 0
Synaptics Circular Scrolling Distance (364): 0.100000
Synaptics Circular Scrolling Trigger (365): 0
Synaptics Circular Pad (366): 0
Synaptics Palm Detection (367): 0
Synaptics Palm Dimensions (368): 10, 200
Synaptics Coasting Speed (369): 20.000000, 50.000000
Synaptics Pressure Motion (370): 30, 160
Synaptics Pressure Motion Factor (371): 1.000000, 1.000000
Synaptics Grab Event Device (372): 0
Synaptics Gestures (373): 1
Synaptics Capabilities (374): 1, 0, 0, 1, 1, 0, 0
Synaptics Pad Resolution (375): 14, 12
Synaptics Area (376): 0, 0, 0, 0
Synaptics Soft Button Areas (377): 655, 0, 820, 0, 0, 0, 0, 0
Synaptics Noise Cancellation (378): 8, 8
Device Product ID (312): 2321, 21128
Device Node (311): “/dev/input/event11”
[gnome@gnome-notebook ~]$ xinput --set-prop 346 65 70 0
unable to find device 346
