Ditto Menu is back ![]()
I noticed this earlier
Just started akregator and saw it in my news feed
Are there any directions for manually adding this menu? I downloaded it and looked on the Github but didnāt find any directions for how to install the download.
In your downloaded .tar.gz there should be a āReadMe.mdā with instructions.
There is not one, itās what I looked for right away after I downloaded it from kde.store.org
It appears I might need to install ocs-url in order to install this - even a manual install? I thought I might be able to copy and files somewhere and be able to try itā¦
I just downloaded it from the link above. Maybe another version?
Edit: Sorry, my fault. Itās for translations.
Copy to here after extracting
/home/UNSERNAME/.local/share/plasma/plasmoids
Thanks, @smokey, that worked. I thought there was a way I just couldnāt remember.
