My laptop’s monitor supports 120hz output which works at it’s full resolution, 2400x1600, but all other resolutions only have 60hz output. This doesn’t happen on Windows 11. This happens for both Wayland and X11 and settings, xrandr, and kscreen-doctor are unable to change it. Could I please get help in fixing this?
Also, xrandr seems to be showing all resolutions and refresh rates, but kscreen-doctor only shows 60hz for all resolutions (and an extra 2400x1600 with 120hz).
System info if it helps:
Surface Laptop Studio (Linux Surface kernel)
11th Gen Intel(R) Core™ i7-11370H (8) @ 4.80 GHz
NVIDIA GeForce RTX 3050 Ti Mobile (525 driver; newer drivers have power issues)
Intel Iris Xe Graphics @ 1.35 GHz [Integrated]
16 GB RAM; 8 GB swap
dalto
November 4, 2024, 10:23pm
2
Can you share inxi -Fxxxz
Here’s the output
Kernel: 6.11.4-arch1-1-surface arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A wm: kwin_wayland with: krunner
vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Microsoft product: Surface Laptop Studio
v: 124I:00060T:000M:0200000D:0B:07F:1C:01P:16Y:0U:02
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Microsoft model: Surface Laptop Studio serial: <superuser required>
part-nu: Surface_Laptop_Studio_1964 uuid: <superuser required>
UEFI: Microsoft v: 26.103.143 date: 08/16/2024
Battery:
ID-1: BAT1 charge: 34.3 Wh (64.5%) condition: 53.2/56.3 Wh (94.6%)
power: 6.8 W volts: 11.6 min: 11.4 model: SMP 1144021020 type: Li-ion
serial: <filter> status: discharging cycles: 58
Info: quad core model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
Speed (MHz): avg: 1254 min/max: 400/4800 cores: 1: 1254 2: 1254 3: 1254
4: 1254 5: 1254 6: 1254 7: 1254 8: 1254 bogomips: 52856
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Microsoft
driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Microsoft
driver: nvidia v: 525.147.05 arch: Ampere pcie: speed: 8 GT/s lanes: 4
bus-ID: f3:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-3: Microsoft Surface Camera Front driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-2:2 chip-ID: 045e:0c1e
class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa dri: iris gpu: i915,nvidia
display-ID: 0
Monitor-1: eDP-1 res: 2400x1600 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 9 surfaces: xcb,xlib,wayland device: 0
type: discrete-gpu driver: nvidia device-ID: 10de:25a0
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.11.4-arch1-1-surface status: kernel-api
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s
lanes: 1 bus-ID: f2:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-10:4 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
Local Storage: total: 476.94 GiB used: 253.24 GiB (53.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZ9LQ512HALU-00000
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: FXV72M0Q temp: 8.8 C scheme: GPT
ID-1: / size: 350.04 GiB used: 142.07 GiB (40.6%) fs: ext4
dev: /dev/nvme0n1p6
ID-1: swap-1 type: zram size: 7.73 GiB used: 1.01 GiB (13.0%) priority: 100
dev: /dev/zram0
System Temperatures: cpu: 27.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.46 GiB used: 5.89 GiB (38.1%)
Processes: 293 Power: uptime: 23h 25m states: freeze,mem,disk
suspend: s2idle wakeups: 17 hibernate: platform Init: systemd v: 256
default: graphical
Packages: 1573 pm: pacman pkgs: 1555 pm: flatpak pkgs: 18 Compilers:
gcc: 14.2.1 Shell: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
