Both Power Management and Screensaver are disabled but my display is going to standby mode. Not only that suppose I am listening to a playlist in Spotify the music stops by itself. Then when I move the mouse display comes back and the song start playing from where it was stopped.
Which settings do I need to modify to stop this ?
DE : LXQT
You posted in the Pub. Here we drink alcohol and tell jokes. If you like I can tell you a few…
DPMS has various enemy shooters that kill it. They may come in with random packages you don’t even know they autostart. It depends on the name of the Pub as well.
I am using LXQT. I was wrong when I wrote that audio too is stopping when using Spotify. My display just went to standby mode again but Spotify kept playing. Then when I moved my mouse display signal got restored.
Check in Autostart applications and find any other relevant utility running.
It could also be a system(d) unit, or a DBUS configuration, or a default Xorg setting.
Check autostarting apps:
# For config autostart
sudo pacman --needed -S dex && dex -ad
# For session running units
systemctl --user list-units -t service
they are both known applications you already setup to not poweroff display
and they would get back on each update of these applications (or reinstalling them)
@joekamprad@sandman
I have done xset s off now I will observe the system the entire day. This is quite troublesome coz I don’t exactly how many minutes to wait to confirm that it worked.
I must mention one point. This is not a mistake. I am 100% sure about this one. The point is the display doesn’t go to standby when I am watching a video using either Firefox or Smplayer.
As I said I didn’t time it. I wrote minutes coz I am sure this takes less than an hour. Yesterday I launched Spotify, selected a playlist, when the songs started playing I manually switched off my display. After 7-8 songs I turned on my display and got “No Signal”. As soon as I moved my mouse display signal was restored.
My plan is to do the same thing today. I will play a playlist & check the display status after 30 mins.
