Hello there,
recently I’ve bought a KVM Switch to be able to switch between my main PC and my WFH-Laptop.
My Setup includes two monitors, the second screen is directly connected to my PC, the main display is connected to the KVM, which in turn has my PC and the Laptop plugged into it.
My plan is to switch the main monitor while keeping the secondary screen always showing whatever I put on there using my PC.
However, when I switch the KVM to the Laptop, it seems that the main monitor gets “unplugged” from my PC, all applications move over to the second screen and rearrange themself. Switching back “restores” my plasma configuration with all the bars, but keeps the application windows on the second screen.
Now I’ve been looking for a way to disable this automatic display detection and “hardcode” my current display setup, so that the “unplugging” of my main monitor doesn’t cause the windows to move. Do you guys happen to know where I can configure this? I haven’t been able to find anything usable online
The Switch I’m using is this one https://www.amazon.de/DisplayPort-Tastatur-Maus-Druckermonitor-USB-Kabel-Switch-Button-Kabel-Stromkabel/dp/B08RHSKKXJ/ref=sr_1_81?crid=2ULR34H6556LW&keywords=kvm+switch+displayport&qid=1671669208&sprefix=KVM+Switch+Display%2Caps%2C68&sr=8-81
The main display is a LG 27UP650-W connected via DisplayPort
Operating System: EndeavourOS
KDE Plasma Version: 5.26.4
KDE Frameworks Version: 5.100.0
Qt Version: 5.15.7
Kernel Version: 6.0.12-arch1-1 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: AMD Radeon RX 6800 XT
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7C91
System Version: 2.0
Kernel: 6.0.12-arch1-1 arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.26.4
Distro: EndeavourOS
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.90
date: 03/17/2022
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 3712 min/max: 2200/4850 cores: 1: 4484 2: 3789 3: 3787
4: 2200 5: 3798 6: 4749 7: 3798 8: 4441 9: 4354 10: 3789 11: 2200 12: 3797
13: 3798 14: 2200 15: 3780 16: 4437
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel
Device-2: MacroSilicon type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
1: 2560x1440 2: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 14.0.6 DRM 3.48 6.0.12-arch1-1)
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: MacroSilicon type: USB
Device-4: Corsair VIRTUOSO SE Wireless Gaming Headset type: USB
Sound API: ALSA v: k6.0.12-arch1-1 running: yes
Sound Server-1: PipeWire v: 0.3.61 running: yes
driver: r8169
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: d8:bb:c1:3f:35:45
Device-2: Realtek RTL8125 2.5GbE driver: r8169
IF: enp42s0 state: down mac: d8:bb:c1:3f:35:44
Device-3: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
IF-ID-1: docker0 state: down mac: 02:42:3f:1d:4e:51
Local Storage: total: 6.48 TiB used: 2.21 TiB (34.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
ID-2: /dev/sda vendor: Samsung model: SSD 830 Series size: 119.24 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD30EZRX-00D8PB0
ID-4: /dev/sdc vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
ID-5: /dev/sdd vendor: Western Digital model: WD20EZRZ-00Z5HB0
ID-1: / size: 287.31 GiB used: 229.4 GiB (79.8%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 29.1 MiB (30.3%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 68.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): fan-1: 790 fan-2: 2312 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 693 fan-7: 0 fan-8: 0 fan-9: 0 fan-10: 0 gpu: amdgpu fan: 0
Processes: 419 Uptime: 6h 9m Memory: 31.27 GiB used: 11.26 GiB (36.0%)
Shell: fish inxi: 3.3.23
Thank you very much for your help!
