When I was using Windows 10, when I right-clicked on packaged files like zip, rar, 7z, etc, I had the option "extract here/extract to subfolder, etc).
On windows, the first option will extract all files without a folder, and the second option will create a folder with the same name and extract the files inside.
But in EndeavourOS KDE I think it doesn’t work exactly the same.
Does anyone know what the difference is between “extract archive here” and “extract archive here, autodetect subfolder”?
I’ve tried both, but I don’t know which is the difference exactly, I haven’t noticed anything different.
If I’m not mistaken “extract archive here” simply extracts the archive to a new directory of the same name, whereas “extract archive here, autodetect subfolder” will, in case your archive only contains one subfolder, extract that subfolder directly, i.e. not create a directory with the archive name.
That way you won’t have a new directory which just contains another directory and nothing else. Just a convenience feature, nothing more.
