Hey all,
last update completely destroyed my system, and I’m not completely sure that is the 5.15 kernel because I’ve also installed the LTS (that during this update remains at 5.10.xxx) and with that also I’ve the same issue.
Basically when I reboot after the update systemd fail to load
systemd-modules-load.service
and my system doesn’t start. It asks to insert root password and throw me in a root shell, from which I can actually do stuff, and also switch to my user, but in which I have no internet and no way to start it (all the interfaces expect to loop one aren’t there, probably correlated to the error mentioned above).
I revert to a previous snapshot and now I’m in my not-yet-updated-but-working system but I would like to investigate why this is happening (and also can be useful to someone else I think)
here a lot of log taken from both the working system and the update and broken one
I haven’t seen anything that guide me to a possible solution that is not revert and wait for a new point version to come out but, well, maybe some of you more expert will see something into that.
There is no guide for an unknown issue. If you were able to revert and have a working system then? Updates don’t just normally destroy your whole system. If you had an update and you weren’t able to boot in both the lts kernel and the regular kernel then that is odd.
I know this is odd and also never happened to me before on eOS or Arch, that’s why I’ve posted it, to see if with the help of someone is possible to understand what’s the actual issue and eventually fix it.
Also is very reproducible on my machine, I’ve tried 3 times the update and every time finished with the same problem…I really don’t know what to think or check more then the logs I’ve already gave.
Check for any failed services prior to update: systemctl --failed
Create a script to upgrade each package one by one and test. I’m guessing you’re already using btrfs or something similar, so use pacman hooks to create a pre/post snapshot after each package upgrade.
only result is snapper-timeline.service loaded failed failed Timeline of Snapper Snapshots
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=AAA5-AE9A /efi vfat umask=0077 0 2
UUID=23539706-dc93-4182-bc08-9f77a17e75d8 / btrfs subvol=/@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
UUID=23539706-dc93-4182-bc08-9f77a17e75d8 /home btrfs subvol=/@home,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=23539706-dc93-4182-bc08-9f77a17e75d8 /var/cache btrfs subvol=/@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=23539706-dc93-4182-bc08-9f77a17e75d8 /var/log btrfs subvol=/@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
tmpfs
could you try removing space_cache from the BTRFS entries ?
this is currently merged into BTRFS to be used per default and seems to cause issues if it is set in addition on fstab.
aren’t you loading new modules with LTS kernel instead of the current one? I would think that kernel modules should go with a kernel that comes with it instead of an older one ?! I don’t understand as a Tester you can use LTS instead of current as that is not testing new/updated software… If I was a tester I would be using current kernel with updated software as you are using a rolling distro. Also most people would be using ext24 not BTRF-S ?? what are you really testing??
Ehmm. Sorry but I didn’t understand what you mean with it. I’m having an issue with a new update and trying to understand what’s wrong with my system. As a lot of people actually using an lts along with the main one because generally when there are this kind of problems booting the lts instead of the main will solve it.
There is so much wrong with this post that I don’t even know where to begin.
Let’s start with:
From the very first line in the first post of this thread:
You do understand what the word “also” means, right?
As the title beside his/her name clearly states, the user is a tester for the Dev ISO - the development version of what will be the next ISO that is released. The user may or may not be using the testing ISO for his/her main system. That is immaterial.
Perhaps you are not aware of what the next ISO will have included?
Edit2: I have btrfs set up and i still have the space_cache settings and i haven’t had an issue. I don’t typically ever run lts kernels unless i had to which is rare.
i think you got confused by the badge @ParanoidNemo have:
This has nothing to do with this thread about an issue he has He is only part of the ISO testing group (part of development)
