I get an error similar to the above error (basically it is the same thing) when I try to boot my EnOS. I tried to mount 3 of my external hard disk at boot using fstab.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=D57D-B3B3 /boot/efi vfat umask=0077 0 2
UUID=f2f94842-8952-4808-9752-1a9608e5af53 / ext4 defaults,noatime 0 1
UUID=e2a61b8c-25b3-4002-a734-0d515d88f483 /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
#UUID=a2c376f0-d0ae-4264-a7f0-867610f6dbca /run/media/sinux/sinux1 ext4 defaults,noatime 0 2
#UUID=a1a64a10-7ac5-4e8d-a327-89ea2bbb2b57 /run/media/sinux/sinux2 ext4 defaults,noatime 0 2
#UUID=177ce77f-6e06-47a6-b1e9-6c3a6b43fb8d /run/media/sinux/sinux3 ext4 defaults,noatime 0 2
I used my USB to log in to the live environment and comment out the 3 externals which allowed me to boot normally. But I’m sure it’s the drive labeled “sinux3” that is causing the issue.
Do I have to format the drive again or is there a way to fix this?
You are missing a 2 at the end of the line for sinux3
You should use systemd-automounts to mount external drives. That way it doesn’t matter if they are connected or not. It won’t impact your boot and you won’t have manually mount them later.
It worked and it seems computer boot time has improved as well after doing what you suggested. I also formatted the drive because I saw few input/output errors while I was copying the files to the backup folder.
