Dell monitor stuck at 60hz but was running 75hz on CashyOS
I recently installed EndeavourOS on my pc and can’t seem to get the disply to run at 75hz there is not option from me to even set it at 75hz it did run at 75hz when I was running CashyOS.
I have tried “lxrandr” also tried changing the display manager and switching from wayland to x11 and back no luck for me.
I have a nvidia GTX 1080ti and the driver is installed.
Please let me know if you need anymore info from me.
what is the result of
xrandr -q
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
HDMI-A-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.29
1680x1050 59.95
1440x900 59.89
1280x800 59.81
1152x720 59.97
960x600 59.63
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.14
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.27
640x350 59.28
nothing there shows that 75hz is supported
you could try just running xrandr and setting the rate however according to the query its not supported.
I’m not sure if you still have cachy installed, maybe it was using a different driver
this article might help, maybe you were loading a different driver version https://www.cyberciti.biz/faq/linux-check-version-of-ko-kernel-module-driver/
Hello @Dreadside!
Would it be possible to tell us the model of the monitor? So far, we only know that it is from Dell, can run at 60Hz (75Hz?) at 1920x1080 and is connected to the Nvidia GTX 1080 Ti via HDMI.
Hi sure it’s a Dell S2721HN I know it does support 75hz because it is even on the specs page and box only thing is that it does not want to run that on endeavour but does on Windows and Cashyos as stated so must be a setting some where or package that need to be installed I’m guessing.
Thank you very much. Could you please post the output of inxi -Fxxc0z?
Edit: According to the arch wiki, the normal Nvidia driver should be used (your GPU is Pascal) .
This is a known bug in the Nvidia driver version 580.105.08-1, I’m experiencing the same issue. You have two options: either stick to 60 Hz for now, or downgrade to 580.95.05 and wait for a fix to be released. Cheers.
Thank you!
Thanks for all the replies and help! I really appreciate it.
You’re welcome :wink:
