Hi all,
i have a problem with gpg decryption. After success encryption i cant open / decrypt the file with the correct key.
Can you add me some advice?
I attached a image of my screen.
Thanks.
ps:. I tried reinstall keyring, kgpg software.
Hi all,
Thanks.
Please do the encryption / decryption on the command line and share the output.
For the future:
Please do not use screenshots in the forum wherever possible. Copying and pasting the text is much preferred.
You are right.
Thanks for the advice.
The solution is next one:
Thank you.
