The following errors are appearing each time the mirrorlist is updated:
==> Warning about https://endeavouros.ip-connect.info/repo/$repo/$arch:
Connection to this mirror failed after 30 seconds.
Continuing.
==> Warning about https://fastmirror.pp.ua/endeavouros/repo/$repo/$arch:
Continuing.
==> Warning about https://mirror.jingk.ai/endeavouros/repo/$repo/$arch:
Update level is 2240/2247, some [endeavouros] packages may be outdated if this mirror is in use.
Continuing.
==> Warning about https://mirrors.c0urier.net/linux/endeavouros/repo/$repo/$arch:
Continuing.
Can anything be done about this? It takes at least extra 90 seconds each time which is very annoying. Maybe consider removing these from mirrorlist?
Mirrors go on and off line for a number of reasons. If you are consistently having issues with the same mirrors then you can comment them out of the mirror list.
How often do you need to update your mirrorlist for a repo that doesn’t include a lot of things critical for day to day use? And someone on the development time correct me, but I don’t think this utility ranks these dead mirrors high enough for you to even get them in normal use, if there’s a mirror that is available and has a good enough connection.
There is a Hook to rank EndeavourOS mirrors after installing or upgrading the related mirrorlist package
So basically it happens after each endeavouros-mirrorlist upgrade. Maybe that needs to be changed or the timeout needs to set much lower. Something definitely needs to be done about this.
I see. During my time with EndeavourOS, I haven’t noticed that many updates to the EndeavourOS utilities. I don’t know how often the development team pushes updates to people for these utilities, thus I can’t really say anything else other than perhaps someone else can help you.
The issue is YOUR the only one having an issue. What can we do? There may be a number of reason you can not connect ranging from the mirror being offline to the mirror being limited in your country to being completely blocked. Sorry you feel like a minute and a half is a major amount of time out of your schedule however there isn’t anything that can be done.
It’s not only about update for me. This happens each time that package is installed or reinstalled and, as you might imagine, this will happen a lot during the testing the OS installation. I’m working on EndeavourOS ARM image for WoA laptops and therefore have to reinstall it a lot.
