ddterm is my goto Gnome extension.
In setting up another computer with Cassini I have configured the settings. When I invoke ddterm (F12) I get:
I know it works because its running on the other PC perfectly.
https://extensions.gnome.org/extension/3780/ddterm/
Maybe I can migrate ddterm and its dependencies from the other computer and copy them onto this. How to do it?
Maybe there is a better way, since tackling the RPM here is not what I had hoped for from the developer as a closed issue.
The https://aur.archlinux.org/packages/gnome-shell-extension-ddterm has it, but all I needed to do was enable the extension.
pebcak
December 23, 2022, 10:50pm
2
The mentioned file comes from the package vte3
Try installing it and see if the issue will be resolved.
It worked!
You really should be a mod @pebcak
Thank you.
pebcak
December 23, 2022, 10:58pm
4
You are welcome! Glad to hear that you got it working!
And thanks for the compliment!
Its not only ddterm I want to migrate. Since the other computer has everything I want on the new one, is there a step-by-step guide to migrating applications?
pebcak
December 23, 2022, 11:14pm
6
Have a look at 2.5 and 2.6:
https://wiki.archlinux.org/title/Pacman/Tips_and_tricks#List_of_installed_packages
Also for most applications the configs reside in ~/.config. I would copy them over on a per case basis.
Firefox, to give an example, have its config directly under home: ~/.mozilla
system
Closed
December 25, 2022, 11:15pm
7
