Dark theme problem - gnome-extensions
Is Adwaita-Dark the only theme that works for this app? Every other dark theme I have tried it is glaringly white?
Adwaita-dark:
Example Dracula-Slim:
If my thinking is correct, the issue has to do with GTK-4.0 support – or, in this case, the lack thereof.
A good check to see if a theme explicitly supports GTK-4.0 is to check the folder for the theme in question. If there is a GTK-4.0 folder, then the theme fully supports GTK 4.0 apps.
If the GTK-4.0 doesn’t exist, then Gnome will likely default to Adwaita (light) as seen in your screenshot.
Of course! Not considered that :smiley: There are not many around, searching on gnome-look now.
Most of https://github.com/vinceliuice themes are updated. He’s always normally one of the first 3rd party to do so.
(And he’s amazing!)
I use his vimix theme. I checked, and the dark-amethyst variant should be updated. It also works well with Dracula. His WhiteSur theme is also good for Dracula.
I will have a look, thanks!
:edit: it is a no for whitesur:
Found this (skeuos):
Skeuos is a beautiful theme. It’s a shame that it doesn’t fully support cinnamon.
I am using Materia-dark-compact from the materia-gtk-theme package, you can install using yay or pacman and it has extensions darkened.
