Hi everyone, Im quite new to i3 and Endeavour but love it so far. But there is one issue I have, thats with changing my keyboard layout with a different Key shortcut than alt+caps. I switch between german and US internat a lot, but also use some “stranger” keyboard layouts like a Corne. I neither do have alt, nor Capslock programmed on that. So I would like to change the keymapping for changing the layouts.
I tried this, but when I press the keys, nothing changes.
I also tried that with Spaceas space, ctrl+spaceand I guess some others. Lost track a bit tbh. Is there a syntax error in there or can I use only specific keys to change that?
Changing with the default configuration of Alt+Caps works just fine. I just wanted to change the keybinding, because the default one does not work for me.
Thanks for the hint, Ill try again. The strange thing is, I had no issues with that config with the capslock+alt… I just noticed using my sub 60 boards again that the combo is really not good.
