I love playing game on a stretched resolution like 1680x1050. I just swapped from windows to Endeavouros with Gnome 42. I could configure the Resolution to 1680x1050 but i can’t set the Refresh to 240.
xrandr:
DP-4 connected primary 1680x1050+1080+1080 (normal left inverted right x axis y axis) 600mm x 340mm
1920x1080 60.00 + 239.96 143.99 119.98 59.94 50.00
1680x1050 59.95*
1440x900 59.89
I’ve tried to set a new custom resolution with the following commands:
$ cvt 1680 1050 240
# 1680x1050 239.81 Hz (CVT) hsync: 291.14 kHz; pclk: 684.75 MHz
Modeline "1680x1050_240.00" 684.75 1680 1832 2016 2352 1050 1053 1059 1214 -hsync +vsync
$ xrandr --newmode "1680x1050_240.00" 684.75 1680 1832 2016 2352 1050 1053 1059 1214 -hsync +vsync
But i am getting the following error:
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 16 (RRCreateMode)
Serial number of failed request: 47
Current serial number in output stream: 47
Tried to generate other Modelines for 1680x1050_100Hz, 1680x1050_120… etc but non did work.
Using a RTX2080ti with the following driver:
$ nvidia-smi
Thu Jun 9 12:29:45 2022
| NVIDIA-SMI 515.48.07 Driver Version: 515.48.07 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:0A:00.0 On | N/A |
| 0% 35C P0 49W / 300W | 480MiB / 11264MiB | 1% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1067 G /usr/lib/Xorg 193MiB |
| 0 N/A N/A 1129 G /usr/bin/gnome-shell 104MiB |
| 0 N/A N/A 2883 G gnome-control-center 6MiB |
| 0 N/A N/A 6001 G /usr/lib/firefox/firefox 152MiB |
