So, I am using a custom cursor that I know worked properly before.
This cursor only has one size. By default it looks like this:
But, when I move the mouse over the title bar of any app, it looks like:
Anyone know why this is? Happens on GTK or QT apps. Rebooting doesn’t help. I am on Wayland btw.
Does it happen on xorg as well?
What is your global scaling1 set to? Does it happen when you set it to 100%?
1 System Settings → Display and Monitor → Display Configuration → Global Scale
Doesn’t seem to happen on x11. Disappointing. Seems it might be a Wayland thing.
Scale is at 100%.
Yeah, Plasma on Wayland is not bug-free.
It does it on normal KDE also. If i have Firefox open and my cursor goes into the title bar it gets a little fatter maybe a tiny bit larger?
Edit: I don’t usually notice much or worry about it.
